Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
yes, i did that
25th Dec 2018 1:55pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
The lower timing chain cover lines up on dowel / roll pins and the upper timing cover should line up with the lower timing cover.
25th Dec 2018 10:30pm |
hi again
10th Feb 2019 7:32am |
Good news, you will get there.
10th Feb 2019 2:34pm |
yes, i machined up a couple of pieces of steel, put them in the press and it came out fine
10th Feb 2019 11:21pm |
Looks good |
10th Feb 2019 11:30pm |
thanks RR 2005 4.4 petrol
11th Feb 2019 4:07am |
1st Mar 2019 10:02am |
The clips are not sold separately, and they need to be there but you may be able to pick up a connector off of something else as they will be a standard.
2nd Mar 2019 2:10am |
I got a clip, BMW came to the rescue
2nd Mar 2019 10:41am |
Good work, Coolant is the green / blue type rather than the pink, how much difference that makes I'm not sure but i have always run Motul INUGEL EXPERT ULTRA Concentrated Antifreeze in mine.
3rd Mar 2019 6:51pm |
"I would expect some rattles as it starts to fill up the various hydraulic units"
4th Mar 2019 12:00am |
4th Mar 2019 7:45pm |
Early on in the piece I read Haylands post about thermostats, I decided to go for the BMW one.
10th Mar 2019 5:09am |
