Home > Maintenance & Mods (L322) > Rear Heating
Joe Plumber
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Rear Heating
53 Reg V8 petrol heating is working fine in the front of car ! But cant get any heat from rear blower unit , Fan is working but not giving any heat, is there a valve or switch under the centre arm rest that controls the heat ?
Post #507167 3rd Mar 2019 4:32pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Not aware of a valve within the system as air is directed from the front.
The rear vent has two thumb wheels, one for speed & the other for temperature. Are these working ok?
Have you tried switching the front flaps to foot well only & see if that helps?.
Post #507185 3rd Mar 2019 6:27pm
Joe Plumber
Yes the fan speed works OK, its the temp one thats not working, there must be something that it opens & im not sure if it control'd electrically or by a cable, it should work independent of the front controls.may just be a fuse or a relay.
Post #507206 3rd Mar 2019 8:18pm
Weegie
Daft question but when you check the back are you leaving the fronts on a heat setting? The rears cannot be hotter than the front. John
GAP iiD BT
Post #507208 3rd Mar 2019 8:22pm
Joe Plumber
Answer to that is yes but they used to work independent of each other, same as the front each side can give different temp thats why you have 2 x temp controls , the rear has a temp control and fan speed, So some sort of valve must turn heat on or off for the rear passengers,
Post #507240 3rd Mar 2019 10:32pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
There’s a button on the dash to enable control of the rears otherwise it just works to supplement the front temp.
Post #507247 4th Mar 2019 6:49am
