Home > Maintenance & Mods (L322) > Rear Heating |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Not aware of a valve within the system as air is directed from the front.
3rd Mar 2019 6:27pm |
Joe Plumber Member Since: 12 Feb 2019 Location: Devon Posts: 7 |
Yes the fan speed works OK, its the temp one thats not working, there must be something that it opens & im not sure if it control'd electrically or by a cable, it should work independent of the front controls.may just be a fuse or a relay. |
3rd Mar 2019 8:18pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Daft question but when you check the back are you leaving the fronts on a heat setting? The rears cannot be hotter than the front. John
3rd Mar 2019 8:22pm |
Answer to that is yes but they used to work independent of each other, same as the front each side can give different temp thats why you have 2 x temp controls , the rear has a temp control and fan speed, So some sort of valve must turn heat on or off for the rear passengers, |
3rd Mar 2019 10:32pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
There’s a button on the dash to enable control of the rears otherwise it just works to supplement the front temp. |
4th Mar 2019 6:49am |
