Home > Wheels & Tyres > Biggest tyre on 22s?
Danwilderspin
I currently have a set of hawke chaytons with 285 35 22s... I would like a slightly softer ride and was looking at going to as 45 or a 40 profile - does anyone know if there are issues with this? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494837 6th Nov 2018 9:28pm
Standard on the L405 are 275 40 22 or apparently 285 40 22 on some cars, so they should fit no problem
Post #494846 6th Nov 2018 9:55pm
Danwilderspin
I am referring to an l322 though not l405 or are you saying should be fine for that? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494847 6th Nov 2018 9:57pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I’ve got 285/40/22 on my L322 and have no issues on 9.5” wheels with a 45 offset
Post #494860 7th Nov 2018 8:19am
Loads of people running L405 wheels & tyres on L322’s Thumbs Up
You may be able to go slightly bigger, but standard L405 tyres are definitely OK Thumbs Up
Post #494867 7th Nov 2018 8:56am
DBB
United States
A safe option would be 285/40R22. I prefer a wider tire and have had good results with both 305/35R22 and 305/40R22
Post #494957 7th Nov 2018 10:01pm
Danwilderspin
I was trying to go up as many profiles as I could get away with as I know they are prone to cracking Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #494960 7th Nov 2018 10:51pm
Full Fattie
I too was worried about cracking, hence why I went for 40 profile tyres.
I’d say equally as important is the choice of wheel. I’ve read stories about replica wheels being lower quality although I’m sure some are equally good, maybe even better. That’s why I went for genuine LR wheels.
Post #494977 8th Nov 2018 9:32am
Andy
I’ve just bought a TDV8 with Hawke Chaytons. Mine have 285/35x22 and I was wondering what improvement a 40 series tyre would make as well.
I’m not sure if mine is the right offset but the front wheels are flush with the arch compared to slightly inside with a standard LR rim
Post #506768 28th Feb 2019 10:58pm
Aftermarket 22's are sometimes made in two offsets! One for the 322 and another for a 320 (sport) they both fit on the 322 but the 320 wheels sit further out!
To add to this, some manufacturers make 9.0" wide, 10.0" 10.5" & 11.0"... If you get both a set of 320 wheels & a wide setup this can make fitment abit tricky on the 322...
I hope that all makes sense Thumbs Up
Post #506772 28th Feb 2019 11:41pm
Bronjen
United Kingdom 2002 Range Rover Autobiography 4.4 V8 Baltic Blue
Using tyre rolling radius calculations 285/35/22 is the incorrect profile and gives a higher speedo error in relation to the standard land rover wheel and tyre combination.
285/40/22 tyre size is the same rolling radius as original equipment wheels and tyres plus it gives a better ride, tyres can handle the weight of the L322 and discovery 3/4, also the larger profile reduces 22 inch wheels from cracking. Thumbs Up
Post #506795 1st Mar 2019 8:53am
Full Fattie
I’ve got 285 40 22 tyres on my 22” Diaco 5 wheels (9.5”) and the ride is fine.
Post #506804 1st Mar 2019 9:35am
Danwilderspin
Having left it too long and cracked a wheel I think I will bite the bullet Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #508637 13th Mar 2019 11:23pm
Full Fattie
I had a wobble on the steering around 50-70. A bit like an unbalanced wheel.
Took it in to get all 4 checked and expected a cracked/buckled wheel.
They did need balancing but one of the tyres was slightly out of shape. Took the tyre off and the wheel runs straight on the balancer so it needs a new tyre.
Definitely happy I got 40 profile now, much easier to get a tyre than a wheel.
Post #508662 14th Mar 2019 9:51am
