Home > Maintenance & Mods (L322) > Cattle Grid shudder at 50MPH to 55MPH |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Could possibly be a sticking brake or brake calliper, was on mine. Have you checked the wheels for heat after a run? |
15th Feb 2019 3:59pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Hi I had a sticking break calliper last year which caused smoking and a full on wobble steering due to the heat warping the disc at anything over 30MPH. I don't seem to think to could be a calliper problem as this problem only occurs at 50 to 55 MPH and there a lot of people saying online that it points to the Torque Convertor but I will deffo have all the callipers checked to rule iyt out.
15th Feb 2019 4:06pm |
It could well be the torque converter but brake callipers are a lot cheaper. |
15th Feb 2019 4:17pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Way back i used to have a Ford Granada 2.8i Ghia estate and had a similar type of vibration. It turned out to be a split in the propshaft 'spider' joint where the rubber joint had split between the bolts. |
15th Feb 2019 5:34pm |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 |
Probably the torque converter, had mine done a few months ago with exactly the same symptom.
26th Feb 2019 9:58am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As Nicedayforit says you can quickly check for sticking caliper slide pin by the temperature at the wheel. The sticking one will be much hotter. John
26th Feb 2019 10:52am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
jaysta10k, did you get to the bottom of this? 2007 TDV8 VSE
4th May 2019 8:48am |
Hi Still not resolved this issue had front breaks checked again even changed pads had callipers cleaned up etc...I have changed one injector which was number 6 giving an abnormal read no difference though. What is strange is that when engine is cold I do not get the shudder at 55MPH at slight acceleration. I also get shudder when I'm giving it a bit of revs in reverse.I am going to change Injector 1 as this is giving off strange reads to see if this cures it. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
9th May 2019 11:22am |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Watching this with interest, as I have the same issue albeit at slightly higher speed (65-70). Next step for me was also to have the callipers checked, but I'm going to mention the T/C and the prop joint for them to look at. |
9th May 2019 7:19pm |
Hi Cappo do you also get a slight feathering in RPM at about 1500 to 2000 and a vibration shuddering when you reverse only when applying acceleration in reverse though. My gear changes are smooth no slipping and no hesitation up hills etc and the car has no loss of power. It’s doing my head in now I’m hoping it’s an injector issue I will soon know when it’s In for MOT next week they going to change injector 1. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
9th May 2019 7:39pm |
I'll pop out and check those things tomorrow Jaysta - not as I remember, but tbh I don't drive the car that often, once or twice a fortnight generally |
9th May 2019 7:44pm |
UPDATE this has been sorted finally it turned out to be a faulty injector Cylinder 1 so no more shudders in reverse or at 55MPH. But I still have a slight feather on my RPM Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
23rd May 2019 9:00am |
Mine's in being investigated as we speak.... 5.0 S/C Autobiography - now gone to pastures new.... |
23rd May 2019 9:26am |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 53 |
Hi,
23rd May 2019 3:06pm |
