![]() | Home > Maintenance & Mods (L322) > Gearbox oil |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hi All
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3263 ![]() ![]() ![]() |
Personally I wouldn't use it. With the GM box I would stick to the recommended Texaco ETL 7045E John
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
That would appear to be ZF 8HP equivalent, which is backwards compatible with 6HP Oil, which is also backwards compatible with the ZF5 HP oil
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
That’s supposedly a generic fluid ‘suitable for’ the ZF transmissions, not for the GM unit, which requires Dexron III (now superseded by Dexron VI).
Opie have it on there website: https://www.opiecommercialoils.co.uk/texac...earbox-oil John
That's cheap |
The equivalent BMW part is 24 11 7 507 787.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Thank you for the BMW part number will see if have any luck with local BMW dealer, Local Land Rover dealer here in Lincoln has no idea when it will be back in stock if at all ever ! If I could get it out chap I know could no doubt turn one up for me (no cnc machines all done the old fashion way) but if its available to buy I would sooner go that way. |
The thread is M18 x 1.5 x 12mm, if that helps, so it’s fairly generic. Good luck with your search.
