Home > Maintenance & Mods (L322) > Gearbox oil
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Gearbox oil
Hi All
Is the below gearbox oil suitable for a 2005 TD6 auto box?
Post #506202 24th Feb 2019 2:59pm
Weegie
Personally I wouldn't use it. With the GM box I would stick to the recommended Texaco ETL 7045E John
GAP iiD BT
Post #506208 24th Feb 2019 3:58pm
Mikey
That would appear to be ZF 8HP equivalent, which is backwards compatible with 6HP Oil, which is also backwards compatible with the ZF5 HP oil
Now, the Ravenol ZF 6/5HP oil is also suitable for the GM5 box, but whether that specific oil is Compatible for a GM5, I wouldnt like to say for sure...
Post #506219 24th Feb 2019 5:58pm
RRPhil
That’s supposedly a generic fluid ‘suitable for’ the ZF transmissions, not for the GM unit, which requires Dexron III (now superseded by Dexron VI).
As Weegie stated, the original Land Rover specification was for Texaco Texamatic 7045E, but Dexron VI will be fine if you can’t get hold of any. To be honest getting the exact fluid is the least of your worries with the 5L40-E Crying or Very sad
Phil
Edit : Sorry Mikey, I hadn't seen your post.
Post #506221 24th Feb 2019 6:05pm
Weegie
Opie have it on there website: https://www.opiecommercialoils.co.uk/texac...earbox-oil John
GAP iiD BT
Post #506225 24th Feb 2019 6:48pm
Mikey
That's cheap Bow down
I only wish we done enough work with the GM5 box to justify keeping some Laughing
Post #506235 24th Feb 2019 7:29pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
My problem with the gm5l40 on my td6 is finding a replacement filler level plug for the chewed up one on the gearbox so I can check it or an alternative to TGZ000060.
Post #506258 24th Feb 2019 9:22pm
RRPhil
The equivalent BMW part is 24 11 7 507 787.
Is TGZ000060 no longer available?
Phil
Post #506264 24th Feb 2019 11:00pm
kds2
Thank you for the BMW part number will see if have any luck with local BMW dealer, Local Land Rover dealer here in Lincoln has no idea when it will be back in stock if at all ever ! If I could get it out chap I know could no doubt turn one up for me (no cnc machines all done the old fashion way) but if its available to buy I would sooner go that way.
Post #506266 25th Feb 2019 12:35am
RRPhil
The thread is M18 x 1.5 x 12mm, if that helps, so it’s fairly generic. Good luck with your search.
Phil
Post #506412 25th Feb 2019 11:42pm
