Home > In Car Electronics (L322) > I'm in Sussex but my Sat Nav thinks I'm in Manchester!
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
My local Land Rover Main Dealer recently replaced the rear interior trim panel which sits central at the top of the tailgate, with the the rear brake light behind it. The car is an L322, 2007, 4.4 Petrol Vogue. I replaced this trim panel as it was cracked.
Now my Sat Nav worked perfectly before this...... I don't use the system ofter but recently checked it and now it thinks I'm in Manchester, when I'm actually in Sussex! it's not correcting itself either, despite removing disc, etc.
Is the GPS sensor (don't know what the correct term is) located in this area near the back of the cars roof car and is it likely the garage have damaged it when replacing the trim, or am I just been paranoid and it's an unfortunate coincidence?
Many thanks
Post #506167 24th Feb 2019 10:12am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #506168 24th Feb 2019 10:14am
aja500
That's great, thanks for that SKOT - I doubt it's anything to do with the main dealer then, as it's too far removed from the upper rear tailgate trim panel I had replaced.
Will look to replace the antenna
Thanks again
Allister
Post #506169 24th Feb 2019 10:35am
Paul thornton
Just about to say, the GPS antenna is on the roof on an 07 model.
Nothing to say the dealers haven't disturbed it though so it may be worth pulling the headlining down at the back and having a look.
Post #506172 24th Feb 2019 11:11am
aja500
Thanks Paul - Will investigate
Post #506360 25th Feb 2019 7:42pm
