![]() | Home > Technical (L405) > Strange noise on acceleration |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
check for something in the passenger door pocket. |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Only item in the door bin is the headphones in a fabric bag which would be more of a muffled noise if anything. The only way I can describe the noise is like a weight on the end of a vertical coil spring moving backwards under acceleration and then a bouncing noise when coming to rest. Odd I know! None the less I'll take the headphones out and see what happens |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
have a look under the car at the passenger seat location.. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Check that the passenger side seat belt retractor is working correctly.
Thanks for the tips. Had a look under the car and can't see anything loose or untoward. I'll check the seatbelt operation next.
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 246 ![]() ![]() ![]() |
I have a 4.4 2017. I’m getting a whining noise on acceleration. Any ideas what that could be?
After about two years I discovered the culprit in my case.....the air con filter housing box near the glove compartment has a curved hinged lid rather like a kitchen swing bin hence it was opening and closing on hard acceleration / deceleration. Very much doubt that's your problem though, more likely transmission noise of some sort if it's whining or air intake / turbo intake if it's whistling |
Whining on acceleration, is probably drivetrain related, possibly transfer box or diffs. have the oils be changed on these? There is nothing that can't be fixed with a hammer😜😜
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Whining noise under acceleration ? maybe her indoors has just seen the fuel bills |
