Home > Technical (L405) > Strange noise on acceleration |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
check for something in the passenger door pocket. There is nothing that can't be fixed with a hammer😜😜
16th Feb 2019 8:34pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Only item in the door bin is the headphones in a fabric bag which would be more of a muffled noise if anything. The only way I can describe the noise is like a weight on the end of a vertical coil spring moving backwards under acceleration and then a bouncing noise when coming to rest. Odd I know! None the less I'll take the headphones out and see what happens |
17th Feb 2019 10:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
have a look under the car at the passenger seat location.. |
17th Feb 2019 10:55am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Check that the passenger side seat belt retractor is working correctly.
17th Feb 2019 11:33am |
Thanks for the tips. Had a look under the car and can't see anything loose or untoward. I'll check the seatbelt operation next.
17th Feb 2019 6:22pm |
Ukandrewf Member Since: 29 May 2013 Location: South bucks Posts: 215 |
I have a 4.4 2017. I’m getting a whining noise on acceleration. Any ideas what that could be?
9th Mar 2021 4:39pm |
After about two years I discovered the culprit in my case.....the air con filter housing box near the glove compartment has a curved hinged lid rather like a kitchen swing bin hence it was opening and closing on hard acceleration / deceleration. Very much doubt that's your problem though, more likely transmission noise of some sort if it's whining or air intake / turbo intake if it's whistling |
9th Mar 2021 5:46pm |
Whining on acceleration, is probably drivetrain related, possibly transfer box or diffs. have the oils be changed on these? There is nothing that can't be fixed with a hammer😜😜
9th Mar 2021 5:57pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Whining noise under acceleration ? maybe her indoors has just seen the fuel bills
9th Mar 2021 6:53pm |
