Home > Technical (L322) > Rear lights on all the time |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Brake Light Switch:
1st Feb 2019 11:52pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Cheers Joe. Any idea where the brake light switch is? I don’t have an LCM module as mine is a 2011 model so lights go through BCM I believe. 2011 RR Autobiography 4.4 TDV8 |
2nd Feb 2019 7:39am |
Up the top and behind the brake pedal arm - well that is where it was on my TD6, easier access if you remove the trim panel below the dash / above the pedals .
2nd Feb 2019 8:02am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
To me, those look like aftermarket 'black' lamp units. If so, they're really designed to operate with earlier (pre 2010 facelift) cars, with the added circuit board.
2nd Feb 2019 10:39pm |
Well spotted spooky, advertised as "This item will fit all Range Rover L322 models from 2002 - 2013 ( 2002 - 2009 require mount and wiring modification)
7th Feb 2019 7:33pm |
