Home > Technical (L322) > Rear lights on all the time
dirtymonkey38
Hi, bit of an odd one. I noticed the other night when i got out my car and locked it the rear lights were on at the top faintly, would/could this be the fog lights? They went off after 2mins 21 secs (i timed it several times - locking and unlocking the car).
They both seem to remain on permanently while the car is unlocked with or without the engine running. This is with the auto lights turned off but also does it if the light switch is set to auto mode. Im baffled to the reason why. Nothing is showing on IIDTool, no lights on the dashboard either. Being a 2011 model there is no LCM module (that i am aware of).
I have checked around the passenger seat front and rear for any damp or wet carpets and its dry. Anyone experienced this before or have any suggestions?
Picture below if it helps
 2011 RR Autobiography 4.4 TDV8
Post #503611 1st Feb 2019 8:39pm
Brake Light Switch:
Remove, clean (WD40/Contact Cleaner), Test, or Replace
LCM:
Check fault codes
(found behind lower A pillar trim, above bonnet release) .
Post #503626 1st Feb 2019 11:52pm
dirtymonkey38
Cheers Joe. Any idea where the brake light switch is? I don’t have an LCM module as mine is a 2011 model so lights go through BCM I believe. 2011 RR Autobiography 4.4 TDV8
Post #503630 2nd Feb 2019 7:39am
Up the top and behind the brake pedal arm - well that is where it was on my TD6, easier access if you remove the trim panel below the dash / above the pedals .
Post #503632 2nd Feb 2019 8:02am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
To me, those look like aftermarket 'black' lamp units. If so, they're really designed to operate with earlier (pre 2010 facelift) cars, with the added circuit board.
There's a testing signal applied by the CJB which causes this. You'll most likely have a few fault codes stored, too ... Wink Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #503764 2nd Feb 2019 10:39pm
dirtymonkey38
Well spotted spooky, advertised as "This item will fit all Range Rover L322 models from 2002 - 2013 ( 2002 - 2009 require mount and wiring modification)
No fault codes though. Never noticed before so maybe its done it since they were fitted but only seeing them now the nights and mornings are dark. Need to find a fix as no option on IIDTool to alter hot/cold monitoring on a 2011 car. 2011 RR Autobiography 4.4 TDV8
Post #504374 7th Feb 2019 7:33pm
