Home > Maintenance & Mods (L322) > loud clicking from behind dash
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
This problem started today, car starts and drives with no issues, I have no idea what it could be. After car has been left for 15mins or so, presumably all systems have gone to sleep, when I open the driver's door there is a loud clicking from behind the dash somewhere, it goes for about 10 seconds then stops. closing and opening the door does not make it start again until the car is left for over 15mins again. It sort of sounds like the click when you turn the key but it seems to go in quick bursts of 3, click click click - click click click Any ideas? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #503992 5th Feb 2019 10:32am
mpirie
Ventilation blend motor?
Mike
Post #503993 5th Feb 2019 10:34am
wayneg
Do the blend motors go through a test sequence? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #503994 5th Feb 2019 10:49am
mpirie
I'm not sure if they do, but when you switch the ignition off, they will assume their default position and if the nylon gears have stripped or jumped, then the motor may not be able to find its home.
Have a search, i'm sure someone posted a video with sound of a similar problem.
Mike
Post #503996 5th Feb 2019 10:52am
wayneg
Mike, thanks for the pointer, Did a search for blend motor and bingo seems spot on. Funny how you think you know most thing that are likely to fail but this one is new to me. Now to find a used one in Oz.... 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #503997 5th Feb 2019 10:54am
mpirie
I don't think a new replacement costs too much.
I'm sure Dan at Duckworths would be able to sort one out for you.
Mike
Post #504106 6th Feb 2019 8:44am
wayneg
Fingers crossed it might have been sorted. I removed the unit and removed the motor from the gearbox and it all seemed to move freely. I reassembled it connected back to the cars wiring then changing all the heater controls observed the final gear turning quietly. All good I thought so all back together, left the car for 30mins then opened the door to Click Click Click...... Took the unit out again and this time opened the gearbox, it all looked good and moved freely but I greased it at the appropriate points, reassembled, refitted and left the car. The next time I opened the door no clicking, I put my hand on the motor and could feel it working.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #504108 6th Feb 2019 9:13am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Thanks for the pics and the explanation Thumbs Up
Post #504113 6th Feb 2019 10:30am
mpirie
Thumbs Up Thumbs Up Thumbs Up
Post #504196 6th Feb 2019 10:27pm
wayneg
I have now had 2 weeks of silent entry so can conclude opening the blend motor gearbox to clean and re-grease cured my problem without the need for new parts. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #505880 21st Feb 2019 9:53am
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Great writeup Wayneg, seems as though a few of us are suffering this now.
Could you give some guidance on where that motor is located and how you got it out please.
Post #549045 1st Apr 2020 8:53am
wayneg
I can confirm my problem has not reoccured.
write up on removal here... https://www.fullfatrr.com/forum/topic48139...lend+motor 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #549058 1st Apr 2020 9:58am
JohnK
Thanks again for the info, took it out and greased, will see if its cured it when i connect the battery back up later today.
Post #549133 2nd Apr 2020 7:48am
wayneg
Let us know how it goes 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #549137 2nd Apr 2020 9:34am
JohnK
Well I thought it had fixed it. Sad
First couple of unlocks the noise was gone, now it's back but slightly different sound.
There were several "lumps" of dried grease in the gearbox that i thought was the issue, gave it a good clean and degrease and fresh grease on assembly.
All the teeth on the gears were clean and in good condition and no play on their shafts.
Flap that it drives seems free too, so it's not that.
I shall have to take another look.
Post #549215 3rd Apr 2020 9:36am
