Home > Technical (L322) > HDC-ABS-Warning-Susp lights
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all
2004 L322 TD6. Car was running fine but failed MOT on O/S/F track control arm.
Put it on full O/S lock. I had to remove the steering arm as couldn’t get the track rod end off of it whilst on the car. Fitted New track rod end (same length, 26 turns off and 26 turns on). Put it all back together but now steering wheel is out by about 1/4 turn.
Went to start it but key wouldn’t turn in ignition lock. Eventually got it to turn by rocking steering wheel like steering lock was on.
Also (maybe coincidence?) within 5 mile I got the HDC, ABS, Susp inactive, and warning triangle light up? It resets by turning key on and off. But also comes back on after 3-4 miles.
Suspension (when reset by turning key on and off) goes from normal to high (slow but does go) but won’t go from normal to low. The low light doesn’t come on at all.
Battery was big and new 1 year ago.
Have put Icarsoft on it and not showing no errors. In fact with all the the warning lights on, when I plug the icarsoft in the lights go out?!?!
What’s my chances of putting battery on charge all night and it magically fixing itself??
Cheers for any hope!
Tel Accept, some days your the pigeon, some days your the statue!
Post #504184 6th Feb 2019 8:53pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Well thats interesting.
My car has been activating traction control all the bloody time-any acceleration and or turning.
Anyway, I went to a specialist today and he said its all because my N/S/F trackrod end is goosed. Says the car thinks its turning too much and in a skid etc.
He told me to replace the track rod, get it aligned then take it back to him to clear the codes properly.
I also have an icarsoft, but the level of detail he got on his machine was much better Thumbs Up
I suggest you get a 4 wheel alignment and go from there.
Post #504187 6th Feb 2019 9:07pm
philip1972
By the way, my errors came and went by themselves too.
Post #504188 6th Feb 2019 9:08pm
Boydonegood
Does it lock out the suspension, and ABS lift on your Philip? Accept, some days your the pigeon, some days your the statue!
Post #504189 6th Feb 2019 9:11pm
Boydonegood
Post #504190 6th Feb 2019 9:13pm
philip1972
When I reset the code, its OK for a few mins, but then "suspension inactive" comes up and it wallows like a container ship and wont go up and down properly.
He said the ABS is cutting out the suspension as its all linked, or something. He is a very well respected specialist, and seems convinced that this is due to the passenger front wheel pointing in the wrong direction, due to all the play in the ball joint at the end of the track rod. This means the car things the steering angle is waaayyy over parameters hence the traction cutting in (which uses the ABS system).
Mind boggling for a luddite like me, but he knows his onions.
Post #504191 6th Feb 2019 9:17pm
Boydonegood
Your a star fella. At least it’s give me some hope that it may not be “the end of the world” to fix.
I’ll charge battery to see, but yeah next step is to get it aligned and fingers crossed!!
Thanks so much for your thoughts Accept, some days your the pigeon, some days your the statue!
Post #504193 6th Feb 2019 9:19pm
philip1972
I have been having a nighmare too.
I just bought a new battery yesterday because I thought that might be the issue Rolling Eyes
Still, the old one was a bit knackered so not the end of the world.
Poor alignment would also explain why the car felt a bit unsteady.
Fingers crossed this fixes it (for both of us).
Post #504194 6th Feb 2019 9:22pm
Boydonegood
Just had a quick look and the wheels aren’t pointing opposite directions like I thought it would need to be to cause a fault?
The steering wheel is sitting about a 1/4 turn off, which I can’t explain?? The track rod end was put back on the same amount of turns the old one came off and they were the same length. Accept, some days your the pigeon, some days your the statue!
Post #504197 6th Feb 2019 9:27pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Had the same problem, a simple wheel alignment solved it straight away. Get that sorted, clear the codes, problem solved
Post #504198 6th Feb 2019 9:29pm
Boydonegood
All I’m hopeing is I haven’t damaged anything whilst pulling the suspension about getting the track rod end and steering arm off.
If tracking was the problem it would be awesome!! Accept, some days your the pigeon, some days your the statue!
Post #504199 6th Feb 2019 9:29pm
philip1972
I dont think it needs to be far out-we are talking a few degrees, not really visible to the human eye.
Not sure about your wheel being off centre, but the new track rod will be holding the front wheel in a different position than the old worn track rod, thats for sure.
Post #504200 6th Feb 2019 9:37pm
Boydonegood
You guys are awesome as always
Thanks so much. Will get it tracked and report back
Fingers crossed Accept, some days your the pigeon, some days your the statue!
Post #504235 7th Feb 2019 6:37am
Boydonegood
Hi all.
Just an update. Took car to be tracked this morning and they were 21mm out. I still can’t explain how, but it was fact. They have re-aligned them and I’ve now got everything working again. No lights and full working suspension.
Guys I just want to say thank you so much for your time and advice/suggestions. If it wasn’t for the kind people in this forum I truely could not afford to keep running such a lovely car.
Your absolute stars. Thank you so much!
Post #504480 8th Feb 2019 3:28pm
gj88
Spot on mate, always nice when it's a simple solution! Thumbs Up
Post #504501 8th Feb 2019 5:02pm
