![]() | Home > Technical (L322) > HDC-ABS-Warning-Susp lights |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Well thats interesting.
By the way, my errors came and went by themselves too. |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Does it lock out the suspension, and ABS lift on your Philip? Accept, some days your the pigeon, some days your the statue! |
When I reset the code, its OK for a few mins, but then "suspension inactive" comes up and it wallows like a container ship and wont go up and down properly.
Your a star fella. At least it’s give me some hope that it may not be “the end of the world” to fix.
I have been having a nighmare too.
Just had a quick look and the wheels aren’t pointing opposite directions like I thought it would need to be to cause a fault?
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Had the same problem, a simple wheel alignment solved it straight away. Get that sorted, clear the codes, problem solved |
All I’m hopeing is I haven’t damaged anything whilst pulling the suspension about getting the track rod end and steering arm off.
I dont think it needs to be far out-we are talking a few degrees, not really visible to the human eye.
You guys are awesome as always
Hi all.
Spot on mate, always nice when it's a simple solution! |
