Home > Maintenance & Mods (L322) > Track rod end wont unscrew?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Doing the passenger side tyrack road end.
Got the ball joint out OK, wound back the locking nut, but am fooked if I can unscrew the end?
Any tips?
Post #504148 6th Feb 2019 5:21pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
Forgive me for asking but could it be a left-handed thread?
Post #504149 6th Feb 2019 5:27pm
sparkysim
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I guess it depends on how liberal the last mechanic was with the anti-seize. They can be a bit tight at times, take the inner and outer off in one go and take it to the bench vice if it’s too solid to split under the car. Personally if your in there I would change inner and outer anyway, for the small price of parts it’s worth doing.
Good luck!
PS: not left hand thread by the way
Post #504150 6th Feb 2019 5:38pm
philip1972
I guess it could be-but I didnt think so.
It will just not move and I am struggling to grip the inner track rod enough to stand on a breaker bar!
Post #504151 6th Feb 2019 5:39pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Spray liberally with plusgas stixk the ball joint back and use the flats on the track rod to get it moving - go either way to break it loose
If that doesn’t work , gonna need heat 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #504152 6th Feb 2019 5:53pm
philip1972
I gave up ha ha!!
Took the whole track rod out (inner and outer) and whacked it in a vice.
Even with a 6 foot scaffolding pole as leverage it would not move an inch-quite amazing. The stilsons ended up bent!
Not going to try any more, I will just get an inner tomorrow and be done with it.
Thanks for the advice Thumbs Up
Post #504155 6th Feb 2019 6:44pm
chrisdaviescd1
2007 Range Rover Vogue TDV8 Zermatt Silver
I was fortunate that mine came off easily, in the past I have found that heating with a good blow lamp or oxyacetylene torch then immediately chilling with water is very successful.
Post #505007 13th Feb 2019 10:49am
