![]() | Home > Technical (L322) > Rear Adaptive Dynamics Fault |
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 ![]() ![]() |
Hi All,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Jon check out this post: http://www.fullfatrr.com/forum/post474451.html#474451
Does sound very familiar - and answers my question about if you can get to the wires - thanks! |
Andyv8 Member Since: 02 Feb 2019 Location: Lakes Posts: 15 ![]() ![]() ![]() |
Randomusername did you ever solve the problem? Mines just come up with the same fault. |
I checked the wiring over the top of the fuel tank and it all seemed OK, unplugged and checked the wiring on the sensor end and couldn't see anything amiss...
I’ll have a look and check all the wires tomorrow. I’ll let you know tomorrow what I find. |
I'd check the contacts carefully for damp / corrosion, with the cold/wet weather water might have got in there and caused the issues... |
Will do, thanks for the heads up |
