![]() | Home > Technical (L322) > Sudden Adaptive Dynamics Fault |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
I guess an easier question might be if anyone knows where the wiring from the sensor actually goes? Does it run parallel with the air line under the rear arch liner?
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
I've replaced both of my loom sections going into the strut tops. It's really obvious where the breaks occur. There is a rubber grommit on the inside of the strut top and if a wire is broken, it will be just around the entry point, would take 30 seconds to check, fixing it is dead easy as well, go and have a look, we'll be here... |
I assume you are talking about the front strut tops? I checked those were OK before running the fault codes and they were OK anyway. The rear ones look fine from inside the boot.
I would phone Mikey, he's the man to get you sorted. |
Sorry I dont know who Mikey is?! Not been on for a while as Td6 has been behaving itself for once and this is first problem TdV8 has had
MMP Landrover, Indy in Dundee. https://www.facebook.com/MMPLandRover/ |
For anyone interested the fault was chaffing of wires over the fuel tank apparently. i changed the rear height sensor to no effect and so left it at dealer while away playing in the snow
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
Andyv8 Member Since: 02 Feb 2019 Location: Lakes Posts: 15 ![]() ![]() ![]() |
Sorry for bringing a old thread back to life, mines just come up with Thai wax to fault. Was it the wires going to the dampers that was damaged? Just that when you look on live values the height sensor is working. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Andyv8 not sure what a Thai Wax is? You may need another kind of forum for that! |
randomusername Member Since: 28 Mar 2017 Location: Wilts Posts: 56 ![]() ![]() |
That's pretty much what mine was doing (on the other thread). From what I can tell there's two sensors in one unit - one is for adaptive dynamics, the other is vehicle height for the air suspension - which is what the IID tool displays as a live value... |
fearless 1 Member Since: 21 Aug 2019 Location: Burntwood Posts: 2 ![]() ![]() ![]() |
Hi, Any help would be appreciated.
Mikem Member Since: 13 Jan 2019 Location: Kent Posts: 48 ![]() ![]() ![]() |
I have the same having renewed both front wiring repair kits my warnings are still coming on checked the rear wiring and they seem ok |
