![]() | Home > Technical (L322) > Sudden Adaptive Dynamics Fault |
Mikem Member Since: 13 Jan 2019 Location: Kent Posts: 48 ![]() ![]() ![]() |
Have you had any joy with the issue |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Fearless 1, what was the outcome of the U3000-01 fault? I’ve just had the exact same after my MOT test was done and the idiot tester did a braking test with the car in off road height so has obviously triggered the fault.
I managed to sort mine this afternoon. Wires to dampers all seemed intact and fuse and relay in the rear junction box all good too. Thought it must be something to do with the Control Module not getting power or maybe the module itself, so got it all out of the rear quarter to start fault finding with a multimeter and the fault disappeared. It must’ve been a dodgy connection in one of the plugs so gave them all a good spray of contact cleaner and hope that’s solved it. 🤞 Andy
Kuret Member Since: 07 Feb 2024 Location: Ontario Posts: 10 ![]() ![]() ![]() |
Having the same issue after a front right CV shaft swap. Any suggestions on how to troubleshoot did you solve this? |
