Home > Technical (L322) > Heeeeeeelp !
Page 3 of 3 <123
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
comp
trouble is the compressor tends to run but produce no air if the rings have burnt out-but you should try off a battery as above
just in case the motor in it is kaput
Post #501990 18th Jan 2019 12:21pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Right found fuse blown behind glove box , 15a and a 50a one also blown in the smaller fuse box in the boot , comp runs with direct 12v feed but still nothing , anuthing else i should look at ??
Post #501999 18th Jan 2019 1:50pm
bembo449
Just to ad i have f.code 74 which i can delete , oddly ive just tried 12v direct to the comp again nothing happens
Post #502002 18th Jan 2019 2:27pm
bembo449
Bit of an update , i finally got to the root of my problem , after much testing i found that the bushes had failed in my compressor motor , so i guess its was just bad luck rather than me actually breaking something while calibrating the ride height Thumbs Up
Post #502519 23rd Jan 2019 12:20pm
holidaychicken
Post #502521 23rd Jan 2019 12:42pm
bembo449
Right folks , fitted the new motor to the compressor and it works great , although i cant get the front end to stay up , ive looked in the wiki and there isnt a method for calibrating / adjusting the set up , i feel im not doing tgings in the right order so has someone got an idiots guide to setting up the 322 properly ??
Thanks
Post #503163 29th Jan 2019 9:25am
So it will go up ?
EAS INACTIVE / Lights on dash at any point?
Does your diagnostic tool "speak" L322 ? (properly... e.g. allow for height adjustments at each corner, each axle) ? .
Post #503179 29th Jan 2019 11:53am
bembo449
Yes , it goes up and down using the scan tool and its stayed up over night , its only if i drive it the front goes down again , there are no faults on the dash , the toggle operates but does change the height , so do i need to calibrate it or something else ?
Post #503195 29th Jan 2019 12:52pm
bembo449
Hi folks , after a long illness ( kidneys ) ive finally well enough to look at my 322 again , spent a couple of hours trying to sort my EAS out , i can lift if all up and measure heights on my delphi then swap to solus to confirm calibration , all ok , no faults but as soon as i drive it , the front pops up into off road and the rear drops to lowest , whats going on , its totally different to my original issue
Post #512343 17th Apr 2019 8:25am
Page 3 of 3 <123
