Home > Technical (L322) > Heeeeeeelp ! |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Right found fuse blown behind glove box , 15a and a 50a one also blown in the smaller fuse box in the boot , comp runs with direct 12v feed but still nothing , anuthing else i should look at ?? |
18th Jan 2019 1:50pm |
Just to ad i have f.code 74 which i can delete , oddly ive just tried 12v direct to the comp again nothing happens |
18th Jan 2019 2:27pm |
Bit of an update , i finally got to the root of my problem , after much testing i found that the bushes had failed in my compressor motor , so i guess its was just bad luck rather than me actually breaking something while calibrating the ride height |
23rd Jan 2019 12:20pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
23rd Jan 2019 12:42pm |
Right folks , fitted the new motor to the compressor and it works great , although i cant get the front end to stay up , ive looked in the wiki and there isnt a method for calibrating / adjusting the set up , i feel im not doing tgings in the right order so has someone got an idiots guide to setting up the 322 properly ??
29th Jan 2019 9:25am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
? So it will go up ? EAS INACTIVE / Lights on dash at any point? Does your diagnostic tool "speak" L322 ? (properly... e.g. allow for height adjustments at each corner, each axle) ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
29th Jan 2019 11:53am |
Yes , it goes up and down using the scan tool and its stayed up over night , its only if i drive it the front goes down again , there are no faults on the dash , the toggle operates but does change the height , so do i need to calibrate it or something else ? |
29th Jan 2019 12:52pm |
Hi folks , after a long illness ( kidneys ) ive finally well enough to look at my 322 again , spent a couple of hours trying to sort my EAS out , i can lift if all up and measure heights on my delphi then swap to solus to confirm calibration , all ok , no faults but as soon as i drive it , the front pops up into off road and the rear drops to lowest , whats going on , its totally different to my original issue |
17th Apr 2019 8:25am |
