![]() | Home > Technical (L322) > Chargin the main battery while still connected |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
I've never disconnected a battery from the car to charge it.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
On the basis of recent experience of going from a pre-CANBUS motorcycle to one that has it, where I needed a new charger that was CANBUS compatible, my guess is that if a non-CANBUS charger would put your electronics at risk the battery should be disconnected before charging. This might result in the loss of existing settings, so a CANBUS compatible charger would be the best choice. Perhaps someone who knows more about this in the context of the RR could confirm.
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 ![]() ![]() ![]() |
I think the issue charging motorcycles with a canbus system is that the canbus isolates the accessory socket when you switch the bike off so a standard charger can't connect to the battery through it. A canbus compatible charger sends some sort of signal to the canbus system to tell it to keep the socket live.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Used Ctek for years. Never disconnected the battery at any time.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
I’m the same as Alistair, in having the CTEK connector wired to my battery and the plug strapped to the lower front bumper.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
assuming you have the same 10mm live terminal connector as we do here , it takes just seconds to undo it so why risk it ? ive known folk spike the ECU by leaving it connected ( not on a 322 ) , risk is yours or buy a c-tek as that's seems to eliminate the risk |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I also have a ctek socket connector permanently attached to my battery. The socket connector also has a LED light to indicate battery charge level so I know when to plug in the ctek. ______________________________
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
I have been looking to buy something a bit more gentle than my rather bulky Ring charger. I also like the idea of having a hard wired charging lead. My requirements are mainly to keep the batteries topped up on my 5.0 RR and my 3.2 BMW.
Mine is an mxs 5.0 and it seems to cope well. I try not to let the battery run down too low so it hasn't had to work that hard. Certainly fine for keeping it topped up.
I have the same ctek mxs 5.0 with connector left attached. The connector has the LED charge indicator. This set up works well. ______________________________
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
I got the CTEK 3.7A which also works fine either charging a pretty flat 020 battery or topping up (obviously takes longer to charge though than the larger charger).
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 ![]() ![]() ![]() |
https://www.defa.com/product/chargerkit-1204/
Thanks for the replies guys - appreciate you all taking the time.
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Might be a bit late to the party with this but if you have a towbar fitted don’t overlook the towbar electrical socket option, available in the Shop (above menu bar at top of page, next to Wiki button).
