Home > Technical (L322) > Chargin the main battery while still connected |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
I've never disconnected a battery from the car to charge it.
14th Jan 2019 8:42am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
On the basis of recent experience of going from a pre-CANBUS motorcycle to one that has it, where I needed a new charger that was CANBUS compatible, my guess is that if a non-CANBUS charger would put your electronics at risk the battery should be disconnected before charging. This might result in the loss of existing settings, so a CANBUS compatible charger would be the best choice. Perhaps someone who knows more about this in the context of the RR could confirm.
14th Jan 2019 2:23pm |
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 |
I think the issue charging motorcycles with a canbus system is that the canbus isolates the accessory socket when you switch the bike off so a standard charger can't connect to the battery through it. A canbus compatible charger sends some sort of signal to the canbus system to tell it to keep the socket live.
15th Jan 2019 11:24pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1653 |
Used Ctek for years. Never disconnected the battery at any time.
16th Jan 2019 7:40pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6722 |
I’m the same as Alistair, in having the CTEK connector wired to my battery and the plug strapped to the lower front bumper.
16th Jan 2019 8:30pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
assuming you have the same 10mm live terminal connector as we do here , it takes just seconds to undo it so why risk it ? ive known folk spike the ECU by leaving it connected ( not on a 322 ) , risk is yours or buy a c-tek as that's seems to eliminate the risk |
16th Jan 2019 8:34pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I also have a ctek socket connector permanently attached to my battery. The socket connector also has a LED light to indicate battery charge level so I know when to plug in the ctek. ______________________________
17th Jan 2019 9:47pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
I have been looking to buy something a bit more gentle than my rather bulky Ring charger. I also like the idea of having a hard wired charging lead. My requirements are mainly to keep the batteries topped up on my 5.0 RR and my 3.2 BMW.
19th Jan 2019 9:55pm |
Mine is an mxs 5.0 and it seems to cope well. I try not to let the battery run down too low so it hasn't had to work that hard. Certainly fine for keeping it topped up.
20th Jan 2019 12:09am |
I have the same ctek mxs 5.0 with connector left attached. The connector has the LED charge indicator. This set up works well. ______________________________
20th Jan 2019 12:13am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 125 |
I got the CTEK 3.7A which also works fine either charging a pretty flat 020 battery or topping up (obviously takes longer to charge though than the larger charger).
20th Jan 2019 1:05pm |
kanikune Member Since: 29 Oct 2017 Location: Teerijarvi Posts: 28 |
https://www.defa.com/product/chargerkit-1204/
20th Jan 2019 2:50pm |
Thanks for the replies guys - appreciate you all taking the time.
20th Jan 2019 9:59pm |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 |
Might be a bit late to the party with this but if you have a towbar fitted don’t overlook the towbar electrical socket option, available in the Shop (above menu bar at top of page, next to Wiki button).
21st Jan 2019 2:24pm |
