Home > Technical (L322) > Chargin the main battery while still connected
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Duly ordered the 13 pin variant just now, £28.76
Plus next day delivery for £68 for this badboy https://www.amazon.co.uk/CTEK-MXS-5-0-Reco...amp;sr=8-5
Post #540741 16th Jan 2020 9:47am
DrRob
Exactly how I top mine up.
13pin CTek adaptor (with traffic lights) and a Ctek 10 Thumbs Up
Takes around 4-5 hours to top it right up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540765 16th Jan 2020 1:26pm
fenlander
Good to know thanks - heh I didn't realise the L322 is a early example of a plug in hybrid Smile
Here's a question, is this charging method all good to use when doing live diagnostics with GAP IID tool I wonder?
I understand that battery drain can be a real issue when using the tool so it would be great to keep the charger topping up eg whilst the engine is either idling or not running, ie to eliminate any spurious faults getting reported by low battery condition.
Post #540769 16th Jan 2020 1:43pm
rjff
Doing that should not be a problem. As GAP says in its manual don't leave the IID connected as it does draw current. ISTR others on here do that without any problems. Cheers
Richard
Gap IIDBT
Post #540772 16th Jan 2020 1:59pm
Baltic Blue
Richard,
I can’t fathom out why, but I don’t think it works correctly.
It’s quite a while since I tried it when I first bought my iid. I was sat in the garage with my CTEK connected whilst working through all the various menus trying to familiarise myself .
I noticed that the iid showed 12v at first and started dropping, but I knew that with the CTEK connected. it should have been 13v or more., eventually the low battery warning came on so I removed CTEK, started car and iid showed 13.7v .
Post #540782 16th Jan 2020 3:35pm
rjff
Oh b****r, down in flames again Laughing
Next time I'll try mine with my Aldi charger and see if that works. Looks like a fair useage on the systems when the "ignition" is on for diagnostics. Cheers
Richard
Gap IIDBT
Post #540787 16th Jan 2020 3:52pm
Baltic Blue
I will also play with it again, but when the weather warms up a bit Rolling with laughter
I think the iid reads false voltages because the charger output is pulsed rather than constant ?.
Post #540788 16th Jan 2020 4:11pm
rjff
Mike
I'm not sure on the accuracy of the voltage reading on the IID either, so a voltmeter will be on the battery as a check. Cheers
Richard
Gap IIDBT
Post #540790 16th Jan 2020 4:16pm
Baltic Blue
I will also check with my AVO, you can’t always trust these Chinese Rolling with laughter
Post #540791 16th Jan 2020 4:25pm
DrRob
The IID manual states not to use the Ctek in charging mode as the supply is not clean and steady. The larger Cteks have a Supply mode which should be used with CCF edits. That’s the reason I bought the 10 version 👍
They also warn against running the vehicle in a garage to avoid fumes and death Shocked Censored Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #540793 16th Jan 2020 5:12pm
