![]() | Home > Maintenance & Mods (L322) > 3 Button Key |
Dizzy Dee Member Since: 26 Dec 2017 Location: London Ish Posts: 96 ![]() ![]() ![]() |
Have you tried Timpsons?
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Unnecessary quote removed
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 ![]() ![]() ![]() |
Tried all the Timpsons in the area, every single one says no.
Any other suggestions? Previously...... Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5 TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made, Now 3x FFRR, some would say I should have learned by now...... |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
I bought a couple of these for my tatty keys:
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Are you on facebook?
Thanks, just looked him up and it appears he is in Liverpool, which sadly is a very long way from me.
He still comes to you to do them! -- or he'll do a postal service! Current: 2011 FFRR Vogue SE 4.4 TDV8
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 ![]() ![]() ![]() |
Got the same issue.
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
Timpsons did mine - about a year ago - you need to be nice to the guy!! If it's a definite no then can you not just swap over the innards? |
If you are really clever it's surprisingly easy to remove the metal key from your old keyfob, remove the metal blank from your replacement key and then refit your old key into the new fob. |
How can you remove the blade? Mine seems to be moulded into one half of the key? Previously......
I cut mine out with a craft knife but now I know how they are fitted I would drill it out nextime.
The key is 46.5mm long, the hole centre is 3.5mm from the end. I'll leave you to work it out. ![]() Just a thought, as the key is metal and the old fob case is plastic why not just use a blow torch on it and burn the plastic leaving the metal key. ![]() |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
I ditched the old keys from my 2003 L322 and upgraded to these "flip" keys.
Interesting, but I was under the impression that this type of upgrade to the flip-style couldn't be done for the 2007 models |
