Home > Maintenance & Mods (L322) > 3 Button Key
Balloonengineer
3 Button Key
Any recommendations on where to get my 3 button key refurbished? The rubber switch covers have gone.
I tried the Ebay route, and got a quality blank one, but nobody wants to cut it.
Suggestions, (preferably in the southeast?)
Many thanks
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #501589 14th Jan 2019 11:29pm
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Have you tried Timpsons?
They complain but normally are franchised so will do it for a picture of the queen.
Post #501595 15th Jan 2019 6:39am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Re: 3 Button Key
Unnecessary quote removed
Look no further than this very forum:
https://www.fullfatrr.com/forum/topic39392.html What do I put here then?
Post #501604 15th Jan 2019 8:47am
Balloonengineer
Tried all the Timpsons in the area, every single one says no.
On the above post, alas my 3 button key is not the flip one, its the other one (02-07) which he says he doesn't do!!
Any other suggestions? Previously......
Post #501617 15th Jan 2019 10:18am
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
I bought a couple of these for my tatty keys:
https://bit.ly/2FwKeJs
Post #501619 15th Jan 2019 10:26am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Are you on facebook?
Look for L322 groups and search for Luke Dickinson, he comes to you to do them! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #501622 15th Jan 2019 10:54am
Balloonengineer
Thanks, just looked him up and it appears he is in Liverpool, which sadly is a very long way from me.
But thanks for the suggestion Previously......
Post #501624 15th Jan 2019 11:15am
Bushy30
He still comes to you to do them! -- or he'll do a postal service! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #501629 15th Jan 2019 11:26am
Knightmare
England 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Got the same issue.
Just had a quote from a local independent of £220+ Shocked
I did find someone in North London a few years back. I'll try and dig out the details and let you know. Life is what happens while you�re making other plans.
Post #501776 16th Jan 2019 9:34am
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
Timpsons did mine - about a year ago - you need to be nice to the guy!! If it's a definite no then can you not just swap over the innards?
Post #501787 16th Jan 2019 12:27pm
If you are really clever it's surprisingly easy to remove the metal key from your old keyfob, remove the metal blank from your replacement key and then refit your old key into the new fob. Thumbs Up Saves a great deal of money.
Post #501790 16th Jan 2019 12:44pm
Balloonengineer
How can you remove the blade? Mine seems to be moulded into one half of the key? Previously......
Post #501791 16th Jan 2019 12:47pm
I cut mine out with a craft knife but now I know how they are fitted I would drill it out nextime.
This is what the end of the key looks like.
The key is 46.5mm long, the hole centre is 3.5mm from the end.
I'll leave you to work it out. Thumbs Up
Just a thought, as the key is metal and the old fob case is plastic why not just use a blow torch on it and burn the plastic leaving the metal key. Very Happy
Post #501792 16th Jan 2019 12:59pm
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
I ditched the old keys from my 2003 L322 and upgraded to these "flip" keys.
 2009 - L322 5.0 S/C Autobiography
Post #501801 16th Jan 2019 3:30pm
Knightmare
Interesting, but I was under the impression that this type of upgrade to the flip-style couldn't be done for the 2007 models Sad
Or that's certainly the impression I'd got from the various posts on the forum? Happy to be proved wrong though Thumbs Up Life is what happens while you�re making other plans.
Post #501806 16th Jan 2019 4:13pm
