![]() | Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm? |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
if the bolts that secure the strut to the hub are turning ok (mine were siezed solid) then i reckon removing the hub is the best way to replec the thr bottom ball joint.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Thanks Mark.
So pretty reasonable and so now I'm thinking about blow torches..... EDIT: this is wrong, see two posts down . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 15th Jan 2019 11:24am. Edited 1 time in total |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The arm described as the lower has the ball-joint fitted and its taper fits into the hub. The rear-wards one with the larger replaceable bush is the upper, and as shown in the earlier pictures its ball-joint taper fits into the arm, not the hub and its ball-joint is a separately purchased part. |
Correction just in from Dan:
...which marries up with what you are saying Graeme. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
i havent done the lower balljoint on an l322 yet-i have done similar though,an e53 x5
Ok I'm back to thinking just changing the bush is the way to go.
Anyone know where I can get the bush on it's own? Looks so easy to get to, just right there with the wheel turned: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
you will need the arm off to change the bush which you can get from ebay. not worth the hasle IMHO - just replace the whole arm.
BTW
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Bushes available from advanced factors here https://www.advancedfactors.co.uk/front-su...-287-c.asp
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Oem arms are Lemforder but Delphi will do fine.
As I stated earlier, I R&R'd my 2nd side bush with a bush removal & refitting kit that was already on hand but the 10T press for the 1st side bush was much easier. |
Interestingly it's called the upper arm on the Advanced Factors diagram:
I'm also now seeing the ball joint facing down on that diagram.
Ok I found this:
