Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm?
Page 1 of 5 12345>
GGDR
Not as familiar as some of you with the suspension...
Got an advisory on these front bushes (red arrow)
So a few questions if I may:
1. Done a quick search, am I right in concluding it's easier to replace the arm(s)?
2. Has that arm has a ball joint on the wheel end?
3. If so I guess replacing the arm gets you a new bush and new ball joint.
4. Big job?
. Cheers, Greg
Post #501452 13th Jan 2019 10:30pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It is not that difficult, just need to remember to torque the bolts up with the car at normal ride height with weight on the front wheels.
Post #501465 14th Jan 2019 7:08am
The difficult part on that assembly is getting the ball joint out of the hub, but if you can split the arm from the ball joint without damaging the rubber then changing the arm is easy.
The ball joint is in the hub and can be left and not changed if not needed.
If you damage the rubber on the ball joint end then you will have to change that out which is a bit of a PITA. It will be rusted in position and require hammers, heat and cutting!
So don’t damage the rubber. Thumbs Up
Personally I would doubt those rubbers in the end of the arm are shot. They are meant to have a large amount of movement in them to allow for axle articulation. Did the tester know what he was looking at? There is nothing that can't be fixed with a hammer😜😜
Post #501470 14th Jan 2019 7:53am
GraemeS
I only replaced the bushes - sort of. They didn't look cracked but there was a 3-5mm gap between the bump-stop at the arm end and the centre flat when new bushes don't have a gap. Sure enough the old bushes were found to be very cracked and floating when removed.
I drove out 1 side ball-joint as I couldn't release the taper then used a press to remove the bush. The other side ball-joint wouldn't readily budge so that bush was changed in-situ using a bush change kit. However the ball-joint thread had sustained damage when it slipped off a jack whilst trying to release the taper then the thread snapped off when tightening the nut so a new ball joint had to be fitted anyway.
Post #501473 14th Jan 2019 8:24am
GGDR
Do those ball joints take a good amount of wear?
If the ball joint is ok then maybe as Graeme did (attempted) I should just drop that end and press out the the bush.
Sounds like the ball joint end might be the tricky end anyway (so leaving that end better?)
Or if the ball joint will need doing at some point maybe I'm better to replace the arm with ball joint.
. Cheers, Greg
Post #501483 14th Jan 2019 9:33am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Changing the control arm is not difficult, I did the front passenger side in summer and learnt alot.
Its not so much the arm than it is the ball joint that wear away. So you are best replacing both control arms and the lower ball joint in the hub.
You just need to have the right tools to do the job. I didnt when I started but research and tips on the forum helped me which means when I do the drivers side, it will be a doddle.
You need:
1- proper ball joint splitter (ordinary ones will not do)
2- heat blow torch
3- chisel (i used and sds hammer drill with chisel head)
4- a proper hammer
5- patience and commitment
The ball joint is not easy, the two nuts that hold the ball joint may not come out and then the ball joint will have been badly rusted in. Have a wee search on my posts as Ive got some pictures of when I did it.
Dont just replace the control arm, you will have do it all again as the ball joint will have been worn out too.
Hope this helps.. if you need any help give us a shout. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #501488 14th Jan 2019 10:32am
I think Stan wikified my attempt.... Thumbs Up
Ah no, I didn't detail that bit as it was basically smash it, and heat it, and chisel it and bang it, and drill it, and hate it, and smash it some more........ There is nothing that can't be fixed with a hammer😜😜
Post #501553 14th Jan 2019 5:48pm
Jamiehol
I’ve got to do the ballpoint on mine at the weekend so will try and do a decent write up when I do it for future reference.
Post #501560 14th Jan 2019 6:45pm
GGDR
Thanks guys.
Am thinking at the moment the rear bush and the ball joint are separate jobs.
So I might do the bush(es) leaving the ball joints in.
Then tackle the ball joint(s) when I start hearing "the clunk"
. Cheers, Greg
Post #501568 14th Jan 2019 8:14pm
You need to get the bush aligned properly and will need a tool to wind it out and back in again if you are just swapping the bush. TbH if you can break the taper on the ball joint end without bu**ering the rubber then it’s a damn site easier to swap the whole arm, they aren’t that dear.
You will also need to jack up the hub/strut so that when you torque up the new bush/arm it is in its loaded position so measure from the arch to the centre of the hub before you jack up to start the job and jack up the hub knuckle to the same position before you torque it up. If you don’t do this you risk knackering the bush in short order👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #501570 14th Jan 2019 8:20pm
GGDR
Ok thanks Mark, I'm still getting my head around it....
If an arm comes with a ball joint then hmm maybe replace the whole arm. The blowtorching puts me off. Mainly because I don't have one!
So removing the ball joint end is two rusty bolts?
Or two rusty bolts and a taper?
 Cheers, Greg
Post #501574 14th Jan 2019 8:34pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
The next one of these I do I will def release driveshaft gaiter and roll it back out of the way cover with wet towel and heat the Censored out of it replacement of gaiter a lot easier than fitting new one .Good luck
Post #501579 14th Jan 2019 9:47pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
apparently, these are the handy for getting the ball joint bolts out.
https://www.ebay.co.uk/itm/Bolt-Grip-Nut-R...ctupt=true
Post #501585 14th Jan 2019 10:36pm
rik
Ball joint bolts are the easy bit just don
don't try to force them a bit at a time is the answer
Post #501590 14th Jan 2019 11:38pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
In my experience, absolutely worth their weight in gold Thumbs Up
Over the years, these Irwin's have shifted many a (very) rusty bolt on our RR's. Expensive for what they are but they don't wear out and very often the only thing that will work.
Post #501591 14th Jan 2019 11:48pm
Page 1 of 5 12345>
