Home > Technical (L322) > Oil leak
DrRob
Oil leak
Noticed some driveway spots and a slight burning smell. Underneath the rear of the pan has some oil on it and the suspension cross bar (?)
Doesn’t use oil
Oil cooler or turbo pipe doesn’t look like it’s the issue..just checked it with pollen filter box off.
Never smokes out of the back when pushed
Off to Mark at Petersfield Garage Services in morning for a look-see with pan removed...
Any thoughts....?
Picture to follow in morning.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501231 11th Jan 2019 5:25pm
GGDR
Same here.
. Cheers, Greg
Post #501234 11th Jan 2019 5:50pm
DrRob
Have you had it looked at by anyone? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501235 11th Jan 2019 6:00pm
GGDR
First thing to check is oil cooler - the case can crack or the gasket can go.
Then you want to check the o-ring (search o-ring 4.4TDV8
Both of these are common and can send oil down the bell housing and ends up where you are describing.
Mine's neither.
To try to find it I've had UV dye in the oil and a good search but can't find the source. Still looking.
Doesn't really use oil either. Cheers, Greg
Post #501247 11th Jan 2019 8:04pm
DrRob
Thanks. Oil cooler and feed pipe look ok. Checked those earlier after removing pollen filter box.
Will report back.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501248 11th Jan 2019 8:19pm
stuart_2006
Had similar with my TD6 - garage found small split in one of the diesel plastic fuel lines, and it was diesel dripping, not oil.
Post #501259 12th Jan 2019 12:13am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Keep an eye on your coolant tank for signs of oil?
Post #501266 12th Jan 2019 8:02am
i reckon its oil leaking from the oil cooler or turbo drain pipe and accumulating in the rear 'v' part of the engine..oil gets to much in there and drips down onto the exhaust and then the floor...
Post #501267 12th Jan 2019 8:29am
DrRob
Left it with them. I couldn’t see anything around the cooler when I took the pollen filter box off last night but to be honest it’s not easy to see anything in there with the intake manifold on etc Whistle
Time to crack out the spare motor Thumbs Up
Post #501270 12th Jan 2019 9:06am
Nick591
I have what I think is the same thing on a 2007 3.6TDV8. Oil on the bell housing left side and running down and along under left side of auto box.
I could see oil in the rear of the V between the cylinder banks but hard to get at, even to wipe up.
Where might it be coming from on a 3.6 TDV8? Its not much, just a thin film and a few drops underneath, nothing on drive. Not using oil as such and runs well.
Any thought appreciated.
Nick Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #501304 12th Jan 2019 3:56pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Keep an eye on your steering oil level.
I recently had a leak on one of the banjo bolts on the steering column. Very unusual place for a leak, and took a while to find it.
I initially thought it was engine oil until the steering oil level dropped noticeably. 2007 3.6 TDV8
Post #501453 13th Jan 2019 10:38pm
GGDR
cheezels that's really interesting. I've put UV dye in my oil and still couldn't find anything with the UV torch.
But there oil down there, same as Dr.Rob...
So when you say maybe it's not engine oil you've got me sitting up straight!
Whereabouts are the banjo bolts please?
. Cheers, Greg
Post #501455 13th Jan 2019 10:44pm
cheezels
Banjo bolts opposite position two.
Oil has been known to leak from the seal above this, also.
Remove engine tray and view from below 2007 3.6 TDV8
Post #501457 13th Jan 2019 11:02pm
cheezels
 2007 3.6 TDV8
Post #501459 13th Jan 2019 11:03pm
DrRob
Thanks for the additional information Thumbs Up Will report back when I have a diagnosis Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #501474 14th Jan 2019 8:28am
