Home > Technical (L322) > Oil leak |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Diagnosis in. Oil cooler gaskets (I was dreading it might have been a turbo )
14th Jan 2019 4:47pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Dr Rob, there is a common EGR fault code....
14th Jan 2019 4:51pm |
The code is: P040D-00 (2F) Exhaust Gas Recirculation Temperature Sensor A - circuit high
14th Jan 2019 4:52pm |
OK, thanks. Will ask....
14th Jan 2019 5:03pm |
If you are getting that error code it's a probe (sensor) around £75.
14th Jan 2019 5:09pm |
(Sorry about the typo)
14th Jan 2019 5:10pm |
Looks like it’s chepaer and easier to get a main dealer to change out the NS sensor.....who’d have thought that Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Jan 2019 6:17pm |
I'm going to get the EGRs done anyway (only money!)
15th Jan 2019 12:17pm |
EGRs not being replaced. A vacuum pipe was found to be disconnected which probably threw up the intermittent EGR fault error codes on the diagnostic.....
16th Jan 2019 3:47pm |
L322 Newbie Member Since: 22 Mar 2017 Location: Boldon, Tyne & Wear, UK Posts: 26 |
Hi all,
16th Jan 2019 4:19pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Steve what was your main oil cooler leak? Cooler itself or gasket? How did it show up on the car (i.e where did you see the oil)? Did you fix it yourself and if so how difficult was it? What age and mileage is your FF?
17th Jan 2019 10:45pm |
