Home > Technical (L322) > TD6 Starting/fuel pressure problems...maybe!
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Hi All
We've got a 03 Td6, which has been pretty good for a couple of years. just before Christmas the ole girl started to take a while of cranking before starting. This got worse pretty quickly and now takes pretty much all of the available battery energy to start the thing. Once its running, it'll be fine all day and runs perfectly.
I read the codes on my hawkeye and can see DTC: 9F6 Fuel pressure monitoring whilst starting. suspecting that the inline fuel pump provided initial fuel pressure before starting was at fault, I removed the access hatch and had a friend turn the ignition on whilst I listened and felt it - I can definitely hear and feel it working.
Thinking that the in tank pump must be working too as it runs fine when it starts, so have ruled that out (might be wrong here).
I then pulled the engine covers and looked at the fuel lines to the injectors. With all 6 T pieces from the injectors removed and put in a big jar, I can see fuel peeing out of the hose when the ignition is switched on, so one thinks the car is getting the right amount of fuel.
I then observed the tops of the injectors and I can see fuel pooling in the tops on nearly all of them, with less fuel on injectors 3 and 5 (from the front). Interestingly if one of the 4 digit numbers on the injectors is the date stamp, 3 is 2014 and 5 is 2010. the others are '03, 09 and #08. i.e if the fuel leaking back is the cause, the worst culprits are the older ones.
I don't have leak test kit, but am willing to get one, but even if I do and discover the injectors need replacement, I think I will be o.k getting them out, but how the hec do you get the very rearmost one out, given the limited clearance with the bulkhead/bit under the windscreen.
Any ideas/am I barking up the right tree?
Cheers
neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #500787 6th Jan 2019 7:26pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Plenty of room to remove the rear injector once the pollen filter box has been removed. On top of the fuel filter is a pressure sensor, if there is no pressure you will get an injection system fault message on the dash. The low-pressure side should be close to 4bar, you are able to get a reading with diagnostics. Both tank and external pumps can be had very cheap on Ali Express if you can wait. If you are doing the in-tank pump be sure to have some new hose and jubilee clips as the original must be cut off and cant be reused.
link to tank pump.. https://www.aliexpress.com/item/Brand-New-...4c4dqjIqh1
link to inline pump https://www.aliexpress.com/item/Fuel-Pump-...4c4dqjIqh1 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #500824 7th Jan 2019 8:22am
24valve
Thanks Wayneg for the reply.
There are no dash messages regarding low pressure - just the fault code registered on hawkeye.
I used Hawkeye just now to have a look at the pressure and I am getting 3.9/4 bar pressure prior to starting, so that in my mind seems good. Once its running, it runs lovely, totally smooth and well, normal.
This still makes me think the injectors are at fault, but I still cant correlate the fault code I mentioned with the injectors leaking...but perhaps it does.
With a fully charged battery this morning it took probably 7-10 seconds of cranking before starting. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #500832 7th Jan 2019 10:07am
wayneg
You say the injectors are leaking from the tops, that should not affect running, the plastic t pieces have o rings which must be failing, see this replacement, you can get in brass for a bit more.. https://www.ebay.co.uk/itm/BMW-6-CYLINDER-...rk:37:pf:0
Might be worth doing a leak off test and a live injector test to see if it points to one injector. Strange its running ok once started 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #500833 7th Jan 2019 10:15am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
would you really trust a cheap chinese made pump?
Post #500897 7th Jan 2019 11:12pm
wayneg
Why not, I have both in my car, no issues 30000ks so far. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #500901 8th Jan 2019 4:51am
24valve
Thanks again Waneg.
I'm in the process of sorting a leak test (getting some tubing and bottles to rig something up).
Just to clarify though, once running it runs fine, so I'm still minded to think the pumps are doing whats expected of them.
No problem with changing the T-peices etc though if needed. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #500924 8th Jan 2019 1:08pm
mjdronfield
Mine did similar when I had a TD6, turned out injectors were faulty. If 1 injector is faulty it will start, you won’t notice it, but if 2 go bad it struggles to start. Had 2 recon ones fitted and was fine after.
Garage did it, so I don’t know any codes or anything.
Just a thought and what I was told.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #500925 8th Jan 2019 1:13pm
wayneg
I have had 2 fuel related issues in my ownership. No 6 injector took ages to nail it as it was a very intermittent bad idle. Using BMW ipna live values, after many tries it finally pointed at the injector which proved correct.
2nd issue was the loss of power under full acceleration at speed, not 100% sure but everything pointed at the in-tank pump, I changed both electric pumps and for good measure, the injector loom as I was doing a long remote trip. All good since.
Have you tried Easy Start or similar when cold, easy enough to pull the air hose off the EGR to spray some in. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #500927 8th Jan 2019 1:22pm
SilverParrot
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Do you have more than half a tank of fuel?
I had a problem with the in tank pump which was giving low pressure and would not pull fuel from the slave side of the tank.
Worked fine with a full tank but when getting below half would give all kinds of starting problems.
New pump fixed it, did not have to cut any hoses, just remove unit from tank, split the pump housing and replace pump.
Excellent write-up in Wiki (is for V8 but pump is same).
I just replaced the inner pump on the delivery side.
You can check both fuel gauges from diagnostic menu to check transfer between tanks.
Post #500997 9th Jan 2019 11:48am
24valve
Just updating this thread a bit.
Eventually got fed up of trying to find the right sized pipe for the injectors and ordered a 23 quid test kit from amazon.
Tried it today and it produced clear evidence of 3 of the 6 injectors leaking badly, with the other three starting to push fuel up the pipe. I only ran it for about 10ish seconds.
Next task is to find some reasonably priced injectors...this ones gonna cost!
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #502333 21st Jan 2019 9:14pm
wayneg
Suppose it depends on how much you want to spend, You can get yours reconditioned for less the 100 each or take a punt on used like these on ebay.. https://www.ebay.co.uk/itm/1xDIESEL-FUEL-I...ctupt=true
They are supposed to let a little bit of fuel through so all will leak a bit even when good 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #502348 21st Jan 2019 10:42pm
24valve
I think I'll take the safer option and try and get them fixed.
There's a couple of places locally (Cornwall, where I'm at) that look like they'll sort them.
Fingers crossed. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #502350 21st Jan 2019 11:04pm
