![]() | Home > Technical (L322) > TD6 Starting/fuel pressure problems...maybe! |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
Hi All
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Plenty of room to remove the rear injector once the pollen filter box has been removed. On top of the fuel filter is a pressure sensor, if there is no pressure you will get an injection system fault message on the dash. The low-pressure side should be close to 4bar, you are able to get a reading with diagnostics. Both tank and external pumps can be had very cheap on Ali Express if you can wait. If you are doing the in-tank pump be sure to have some new hose and jubilee clips as the original must be cut off and cant be reused.
Thanks Wayneg for the reply.
You say the injectors are leaking from the tops, that should not affect running, the plastic t pieces have o rings which must be failing, see this replacement, you can get in brass for a bit more.. https://www.ebay.co.uk/itm/BMW-6-CYLINDER-...rk:37:pf:0
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
would you really trust a cheap chinese made pump? |
Why not, I have both in my car, no issues 30000ks so far. 2007 TDV8 VSE
Thanks again Waneg. I'm in the process of sorting a leak test (getting some tubing and bottles to rig something up). Just to clarify though, once running it runs fine, so I'm still minded to think the pumps are doing whats expected of them. No problem with changing the T-peices etc though if needed. 2010 L322 Autobiography Black Edition 1975 Land Rover |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Mine did similar when I had a TD6, turned out injectors were faulty. If 1 injector is faulty it will start, you won’t notice it, but if 2 go bad it struggles to start. Had 2 recon ones fitted and was fine after.
I have had 2 fuel related issues in my ownership. No 6 injector took ages to nail it as it was a very intermittent bad idle. Using BMW ipna live values, after many tries it finally pointed at the injector which proved correct.
Just updating this thread a bit.
Suppose it depends on how much you want to spend, You can get yours reconditioned for less the 100 each or take a punt on used like these on ebay.. https://www.ebay.co.uk/itm/1xDIESEL-FUEL-I...ctupt=true
I think I'll take the safer option and try and get them fixed.
