Home > Technical (L405) > Fake main beam headlights..
Page 2 of 3 <123>
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Craig do you do a conversion to the MY18 lights, what does it look like? letters not necessarily in the right order
Post #496579 25th Nov 2018 12:43pm
Mr Tee
Check out his thread, everything you need to know ..
Post #496586 25th Nov 2018 2:13pm
Dixy
a link would have been helpful letters not necessarily in the right order
Post #496590 25th Nov 2018 3:45pm
Mr Tee
Sorry, that’s really lazy man.. go find it yourself..
Post #496592 25th Nov 2018 3:59pm
Dixy here you go sir...
http://www.fullfatrr.com/forum/topic47985.html
Post #496596 25th Nov 2018 4:39pm
Dixy
Thanks Craig.
This post has been edited by the site administration team  letters not necessarily in the right order
Post #496635 25th Nov 2018 7:50pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Same for me, the bi-xenons on my old L322 were in a different class to the ones on my L405, one thing I really miss from the old RR. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #499086 18th Dec 2018 10:23pm
Fancied a light bar on my 405 so.... Here's the results Thumbs Up
Post #499089 18th Dec 2018 10:38pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Looks great, how did you wire it in?
I have 2X 160W LED light bars I want to fit today. They come with very heavy gauge cable so I am a little concerned over how to wire them in without a controller or relay etc.
Post #500739 6th Jan 2019 10:24am
Wired it from a standard old school 4 pin relay sir... Thumbs Up
There is a large (ish) battery cable in the loom near the drivers headlamp. Thats where i got the 12v+ from Thumbs Up
Post #500741 6th Jan 2019 10:40am
Charles89
I don't suppose you would mind doing some kind of guide?
I do have an automotive relay, did you wire it so the main beam triggers it? Or a separate switch inside the car etc.?
I see on Amazon they have the 433mhz remote looms, I was thinking to get this and then program it into my home link garage door opener to turn it on and off, only it states various modes including strobe lights (not fond of a mobile disco) Just a simple on and off is what I am looking for .
Thank you kindly
Post #500742 6th Jan 2019 10:47am
There are many guides of the net for wiring up relays sir. The only thing i added was a switch to the earth wire so i could turn it off when i didn't want it working every time i used full beam! Fog etc etc
See here...
https://www.google.com/search?q=wiring+gui...5dg299g5M:
Post #500743 6th Jan 2019 11:54am
Charles89
Thank you Thumbs Up
Post #500746 6th Jan 2019 12:09pm
Dartanjang
Sweden 2015 Range Rover Autobiography SDV8 Carpathian Grey
As I have a LHD there may of course be differences in the wiring loom, but could you please provide me with a more specific point for a good +12V source for driving the lightbar? I have removed both air boxes and looked around but cannot see an obvious candidate.
Post #669321 18th Jul 2023 10:13am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Just to explain a little what a relay is/ does.
Most have 4 pins two of them are used for the low voltage draw from a new switch or an existing feed ie headlamp main beam, this side does not draw a large current so does not risk burning out the switch. The relay itself is an electronic switch so the other two terminals can then feed the appliance with current direct from the battery or a suitable fused supply. If you were to just wire a powerful set of lamps from a battery through a switch to the lamps you risk the switch overheating and causing a fire. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #669330 18th Jul 2023 12:18pm
Page 2 of 3 <123>
