![]() | Home > Technical (L405) > Fake main beam headlights.. |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1101 ![]() ![]() |
Craig do you do a conversion to the MY18 lights, what does it look like? letters not necessarily in the right order |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Check out his thread, everything you need to know .. |
a link would have been helpful letters not necessarily in the right order |
Sorry, that’s really lazy man.. go find it yourself.. |
Dixy here you go sir...
Thanks Craig.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Same for me, the bi-xenons on my old L322 were in a different class to the ones on my L405, one thing I really miss from the old RR. Steve
Fancied a light bar on my 405 so.... Here's the results |
Wired it from a standard old school 4 pin relay sir... |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
I don't suppose you would mind doing some kind of guide?
There are many guides of the net for wiring up relays sir. The only thing i added was a switch to the earth wire so i could turn it off when i didn't want it working every time i used full beam! Fog etc etc
Thank you |
Dartanjang Member Since: 03 Nov 2022 Location: Vasteras Posts: 15 ![]() ![]() ![]() |
As I have a LHD there may of course be differences in the wiring loom, but could you please provide me with a more specific point for a good +12V source for driving the lightbar? I have removed both air boxes and looked around but cannot see an obvious candidate. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Just to explain a little what a relay is/ does.
