Home > Maintenance & Mods (L322) > Adaptive Headlights Retrofit to 2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
i dont think its just changing the light units ..
29th Dec 2018 10:01pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Adaptive lights use an extra module (AFS module) that controls swivelling and height adjustment during braking and acceleration for both headlights. If there are 16 wires to each headlight connector then the wiring is fitted, which is what I expect, however the AFS module is not likely to be fitted so would need to be sourced. Thereafter the CCF would need to be changed to enable their use.
29th Dec 2018 10:23pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Don’t know the answer to your query, but don’t just go by the look of the light units because I have the below, and I don’t have cornering lights. There are no bulbs in the corner bit.....
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
So, you have a 2012 and your headlamps are black inside... The grey internals found on the 2009> ALL have the cornering reflectors but those without AFS simply don't have LED's in the cornering lights...
29th Dec 2018 11:29pm |
If looking to buy an AFS module then note that it must be from a MY10 or later vehicle as the HS canbus protocol changed for MY10.
29th Dec 2018 11:47pm |
Ah ok.....ignore me then..... I’m confusing the issue.
29th Dec 2018 11:51pm |
Westminster Member Since: 23 Mar 2017 Location: UK Posts: 135 |
OK will check my headlight plug tomorrow and go from there! Thanks all. |
30th Dec 2018 12:01am |
I had a quick look just now and it does have the 16 pin plug and there seems to be a wire going to every pin in the plug.
Would it be as simple as getting this AFS Module you mention and changing the CCF? (Don't know what that means but I'm sure someone more clever than me will be able to do it! Obviously I will need the headlights with the bulbs in too which mine don't have, or the gaps for the bulbs like someone else above said they had but no bulbs. Thanks. |
1st Jan 2019 6:55pm |
Next step if wanting the adaptive lights is to locate the AFS module connector to confirm that you can find it and that it has all necessary wires. The connector will exist because some of the wires that you found in the headlight connector come from the AFS module connector.
1st Jan 2019 7:37pm |
Ok great, I'll have a look. Thanks! |
1st Jan 2019 7:40pm |
Note my added comments re non-adaptive lights. |
1st Jan 2019 7:51pm |
I'm not sure if that applies to me or not?
Do I just pull the carpet back and hope I come across it? |
2nd Jan 2019 10:24am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
No side panel, just in front of the door Current: 2011 FFRR Vogue SE 4.4 TDV8
2nd Jan 2019 11:03am |
The comment was with regard to the earlier reference to lights apparently with cornering lights but not necessarily being adaptive.
2nd Jan 2019 11:06am |
