Home > Maintenance & Mods (L322) > Pre cat Oxygen sensors on m62 v8 - resolved,
Zain
Can someone advise of the correct Bosch Oxygen Sensor (pre cat) part numbers.
(i believe the LR part number is mhk000210)
The engine management light has been on and off for the last few months and the faults come up as:
02 sensor 1 heater before CAT
02 sensor 1 before CAT
Im assuming the oxygen sensors are at the end of their life at 120,000 miles and need replacing???
Post #494480 3rd Nov 2018 12:25am
holidaychicken
Check the wiring is ok, you have 4 sensors so you need to know if you fault is bank 1 or 2, sensor 1 indicates it is the upstream sensor which would throw the fault but it doesn't specify which bank.
the downstream sensors don't do a lot other than check the CAT.
This is the one i purchased along with the removal tool and thread chaser as one of mine was a total pain to remove and i ended up cutting the top off and using a breaker bar and oxy torch, you might be ok..
Unplugging one or the other may help identify which is causing the problem
http://vi.vipr.ebaydesc.com/ws/eBayISAPI.d...cureDesc=0
Post #494488 3rd Nov 2018 9:40am
Zain
I assumed the number 1 meant bank 1 as it states its the upstream CAT ('before CAT'). Or maybe im reading it wrong.
Are the 2 x upstream sensors (bosch part numbers) the same as the 2 x downstream sensors?
(Just googled the part number and it seems prices vary wildly from mid £40s to around £110 per sensor? Whats the catch?)
Post #494523 3rd Nov 2018 4:38pm
holidaychicken
Sorry, Just checked, the one shown on my link is downstream which is MHK000220.
https://www.ebay.co.uk/itm/Genuine-Bosch-0...1712909187
The upstream sensor is
https://www.ebay.co.uk/itm/Lambda-Sensor-0...2413960236
I'm not sure if i fitted a downstream one upstream as i already had it, it may just be the length of cable but could be type of connector so get the right one.
Have a search around the net, the two above are the first two i found.
It could mean bank 1 guess, my diagnostics states bank 1 or 2 and sensor 1 or 2.
The genuine landrover part is the same as is £150 + VAT ish, below is a few comparisons of alternatives plus OEM
https://www.brit-car.co.uk/product.php/125...trol_g_cat
Post #494527 3rd Nov 2018 4:55pm
Zain
Thanks...thats great info.
Bosch sell on Amazon at £51.75 so i'll most probably buy the upstream sensor directly from them.
Apart from clearing down the code after fitting, does anything else need re setting?
Post #494544 3rd Nov 2018 9:40pm
holidaychicken
You should be good to go once it is fitted and the code cleared.
Some diagnostics would clear adaptions and then let it relearn as the Faultmate does from Blackbox solutions and others i would guess.
This is taken from their info.
Reset Adaptation Values: This forces the engine management to reset all currently learned adaptation values to default values. The engine will run slightly rougher after this, but new values will quickly be re-learnt.
If you don't do this then I would expect it to learn anyway, see how it goes
Post #494560 4th Nov 2018 12:47am
Zain
Update: replacement sensors worked a treat, no more engine management light. The fatty feels like it drives and purrs better. (No adaptations were reset).
Now onto the next problem.....on another thread 🙁
Post #498869 16th Dec 2018 11:18pm
holidaychicken
Post #498885 17th Dec 2018 11:06am
