![]() | Home > Maintenance & Mods (L322) > Pre cat Oxygen sensors on m62 v8 - resolved, |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Check the wiring is ok, you have 4 sensors so you need to know if you fault is bank 1 or 2, sensor 1 indicates it is the upstream sensor which would throw the fault but it doesn't specify which bank.
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
I assumed the number 1 meant bank 1 as it states its the upstream CAT ('before CAT'). Or maybe im reading it wrong.
Sorry, Just checked, the one shown on my link is downstream which is MHK000220.
Thanks...thats great info.
You should be good to go once it is fitted and the code cleared.
Update: replacement sensors worked a treat, no more engine management light. The fatty feels like it drives and purrs better. (No adaptations were reset).
