Home > Technical (L405) > Windows fogging up from the inside
Page 1 of 3 123>
Kace
Morning folks
Now that the cold weather is settling in I can't seem to stop the internal windows from fogging up.
My climate is set to auto and the AC icon is lit up but it takes literally half an hours worth of driving to demist from the inside. I end up having to use the front windscreen heated button to assist.
Do you reckon that this behaviour is due to my air con gas being low?
One other observation is that when I set the climate to auto, the fan speed feels relatively high all through my hour long journey, not max but I'd say a pretty audible breeze which does not change speed at all whilst on auto.
Post #498409 13th Dec 2018 11:46am
you have moisture in there somewhere...could be wet coats , a leak by a door etc or the AC is leaking ..
i'd check the carpets for wetness first.
Post #498410 13th Dec 2018 11:51am
Kace
Thanks.
Also noticed that the rear side windows
(the ones in the boot area) do not react when I activate rear window demist from the driver control panel.
Post #498414 13th Dec 2018 12:20pm
Chalky
Re: Windows fogging up from the inside
Unnecessary quote removed
I got the same last night, but it was only the rear passenger and boot side windows. My settings were exactly as Kace's All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #498415 13th Dec 2018 12:23pm
the side windows do not demist, they are antennas..
Post #498417 13th Dec 2018 12:53pm
Bill
Is the setting that allows air in from outside on or recirculating? Allowing outside air in may help.
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #498433 13th Dec 2018 2:16pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
i remember steaming up the windows of my old Mazda 323 back in 1982........ Whistle Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #498435 13th Dec 2018 2:21pm
Kace
The air recircle is not in.
Post #498437 13th Dec 2018 2:28pm
wrong forum bradders Laughing
Post #498438 13th Dec 2018 2:36pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
It is also worth cleaning the inside of the windows with something rough as they build up a residue of gunge, in the good old days I use to use fine wire wool with window cleaner, now I use magic ceramic sponge with window cleaner and then a micro fibre cloth. letters not necessarily in the right order
Post #498444 13th Dec 2018 2:47pm
Bradders
Any suggestions, Stan ? Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #498447 13th Dec 2018 2:54pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Check your pollen filter in the front isn't clogged up and restricting air throughput.
Post #498448 13th Dec 2018 2:56pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
too many folk breathing inside - tell them to stop immediately! Very Happy
Post #498715 15th Dec 2018 11:29am
pld118
Has your windscreen been replaced (is it genuine LR)?
Post #498722 15th Dec 2018 12:32pm
mjdronfield
Think that’s normal to some extent, if it’s damp. You get inside with wet clothes etc and it all goes to make the car steam up.
Mines the same. Generally have to use the heated screen to help first thing in the morning.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #498727 15th Dec 2018 12:54pm
Page 1 of 3 123>
