![]() | Home > Technical (L405) > Windows fogging up from the inside |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Mine does the same all the time at this time of year. My old L322 never did , but I think the side windows were thicker (looked like 2 sheets of glass together when viewing drivers side glass from above) and if I recall, it also had dedicated air ducts in the A columns to direct air onto the windows which my L405 does not. I've given up on the auto setting, ok for summer but useless in winter as doesn't seem to reach the set temperature very quickly at all, so I now just set the fan to a higher speed manually and put the temp around 23 which seems to clear it relatively quickly. Steve
I'll retract the statement about the L405 not having the dedicated vents in the A column, there are some but the air they put out is negligible for the job they are required to do, I even put the air con fan on full but didn't alter the air flow through them, so are they just used by the recirculating option ? Steve
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Have your AC level checked... If you hit AUTO on the climate then that should kick the AC system on, within the AC is a dehumidifier which is why your windows should clear of fog pretty quickly...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7917 ![]() ![]() ![]() |
Mine had started getting more annoying as there every day (weather doesn't help of course) so I bought 2 x de-humidifier bags (presumably silicone crystals) in December - one for the front , one for the back which you microwave to re-use after they have absorbed their limit of moisture - and they worked pretty well initially, but in the now colder weather they weren't clearing it to easily. However, I have now discovered the probable cause of my issues - wet carpets. I was cleaning my rubber mats in this very cold weather and noticed some ice particles between them and my over-carpets. On checking the over carpets they were very damp, but on checking the actual carpets underneath, the front passenger and drivers were wet to the touch. I can't really blame this on wet feet because as I say, I had rubber mats in there which catch all the wet off my boots so now trying to work out why they are so wet? I've checked things like the water dispersal ducts in front of the windscreen and don't seem blocked (although I will be putting water down them to ensure it flows out). My heater appears to work Ok so not a failed heater matrix (but would expect the related smell from this anyway). Anyone had this issue? Steve
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Probably condensation if the rubber mats are always in. |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 929 ![]() ![]() |
My car has gone to the dealer today to have a myriad of things sorted out, one of those being rear passenger windows that take an age to demist.
That's amazing, I'd literally just posted the above and Dick Lovett at Melksham rang to give me an update on my car.
Thanks for that Chalky. I checked my pollen filter and looked a bit dirty, so decided to get a new one so went to a LR independent who sells the filters for £12.99 + vat which was a good price, however, on telling him about my wet carpet issue, he said the most likely cause would be a poorly sealed windscreen (he has had a few in) and would only need a very small gap to gradually let water in over the 5yrs the car has been built. He also mentioned possible blocked drainage ducts for roof etc so will check these aswell. Interesting you also get the low battery warning Chalky, I'm wondering if it is due to the constantly damp carpets sitting maybe on to of wiring looms if that's feasible? Most of my problems appeared to start though after I took early retirement from work so do a third of the mileage and no daily long runs anymore which would prevent the likes of low battery warnings and excess diesel in my oil I believe |
Just got back from collecting my car.
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Turn off the climate control use normal heating |
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
My personal viewpoint is that the fan speed in recent years - from the L405 to the L494 is too discreet and doesn’t provide a wallop of air con from any of the vents. I’ve had several RRS2s and also FFRRs which do not provide volume gusts of air in contrast to my last 59 plate 110 Defender which I used to dry my hair from the front vents at full speed. Hardly discreet though...
After getting my car back yesterday, this morning I have received a "Health Check" video from Dick Lovett, with the technician going under the car and explaining the tyre wear & brake wear and also checking the suspension.
Small update on my wet carpet issues. Checking a LR workshop manual, it had a section that covers water ingress and refers to how to check door seals are sealing correctly - put chalk dust on seals and smear small amount of petroleum jelly where they are supposed to hit door frame, close slowly , re-open and looks for patches where chalk has not transferred to the jelly which means it's not sealing (then wipe chalk and jelly of afterwards of course). I didn't need to do this however as I found that 2 of my door seals were misaligned and 1 was trapped behind the door card for a length of around 15cm. I believe this will go back a few years where I had to have the roof lining changed after air bags went off so the repairers would just pull the seals down then push them back up, paying no attention to the exact position. The door card with the trapped seal had also been changed as air bag charge in passenger seat scorched it slightly. Workshop manual says they have to be fitted in a specific way (starting at upper corners if I remember correctly) and I think it also suggests that once taken off, you replace them anyway. Anyway, re-aligned them and will see if this gets rid of some of the dampness in the car:) Steve
