![]() | Home > Technical (L405) > Windows fogging up from the inside |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
you have moisture in there somewhere...could be wet coats , a leak by a door etc or the AC is leaking ..
Kace Member Since: 08 Sep 2018 Location: London Posts: 13 ![]() ![]() |
Thanks.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 910 ![]() ![]() |
Unnecessary quote removed
the side windows do not demist, they are antennas.. |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1242 ![]() ![]() |
Is the setting that allows air in from outside on or recirculating? Allowing outside air in may help.
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
i remember steaming up the windows of my old Mazda 323 back in 1982........ |
The air recircle is not in. |
wrong forum bradders |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 ![]() ![]() |
It is also worth cleaning the inside of the windows with something rough as they build up a residue of gunge, in the good old days I use to use fine wire wool with window cleaner, now I use magic ceramic sponge with window cleaner and then a micro fibre cloth. letters not necessarily in the right order |
![]() Any suggestions, Stan ? Current: FF Westminster money pit Gone: RRS 4.2 SC RRS 3.6 TDV8 FL2 TD4 |
Check your pollen filter in the front isn't clogged up and restricting air throughput. |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
too many folk breathing inside - tell them to stop immediately! |
Has your windscreen been replaced (is it genuine LR)? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7851 ![]() ![]() ![]() |
Think that’s normal to some extent, if it’s damp. You get inside with wet clothes etc and it all goes to make the car steam up.
