Home > Technical (L322) > 2003 TD6 Steering freeplay
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
Guys,
I have tried to search past posts for this issue, but can't seem to find what I am looking for.
My 2003 TD6 steering wheel has about 20 - 25mm of freeplay, i.e: Movement of the steering wheel which does not translate in to movement of the road wheels.
I am about to head into the garage to get to the bottom of it, but I was wondering whether:
1) This is a common fault?
2) Has anyone experienced this freeplay and if so how was it resolved?
Thanks,
Stephen
Post #49641 10th Feb 2011 8:22pm
sharpm
Scotland 2006 Range Rover Vogue SE Supercharged Stornoway Grey
Yes I have experience of this
The previous SC I had suffered exactly the same problem which was most noticable on the motorway when cruising
I asked dealer to look at it when in for a service but they could find nothing wrong and could not detect it during a test drive
I insisted there was a problem and went for a drive with head tech who did eventually detect the movement
I was sure that the movement was in the steering column before reaching the rack as the amount of force required on the wheel to feel the freeplay was very little, just the weight of your finger was enough
I got them to put it on the ramps and have a look
the problem turned out to be a loose pinch bolt on the bottom steering column UJ and luckily it wasn't that loose that the splines were knackered so all that was needed was to tighten the bolt - fixed FOC
hope your fix is as simple this but defo worth a look before you start replacing any parts
Post #49645 10th Feb 2011 8:50pm
Track rod ends are a common fault on these vehicles
Post #49650 10th Feb 2011 9:22pm
Landrover Mad
Sharpm thanks for your help you hit the nail on the head - the pinch bolt was indeed loose.
READERS- PLEASE NOTE, IF YOU FIND YOU ARE EXPERIENCING FREEPLAY AT YOUR STEERING WHEEL PLEASE CHECK ASAP THAT YOUR PINCH BOLT AT THE LOWER STEERING COLUMN UJ IS TIGHT!!!!
As an experienced technician I am astounded at how loose this important pinch bolt was, the column is of course still held by splines but if over time they became worn....
Stephen
Post #49937 12th Feb 2011 9:38pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
could we have a pic to determine exactly were we are looking Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #49939 12th Feb 2011 10:02pm
It would be worth applying some Loctite before tightening
Post #49952 12th Feb 2011 11:11pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
pretty sure mine does this. I'll get it check tomorrow. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #49958 12th Feb 2011 11:23pm
sharpm
glad I could be of assistance.
Post #50140 14th Feb 2011 11:16am
