![]() | Home > Maintenance & Mods (L405) > L405 SDV8 oil leak help needed |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
The engine is designed for top down maintenance, and is fitted with an oil extraction tube.
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Well... every day is a school day |
From the workshop Manual for the same engine in an L322.
swissomatic Member Since: 16 Feb 2016 Location: Charleston SC Posts: 48 ![]() ![]() ![]() |
Interestingly Caterpillar diesels in mining trucks were available for a while with oil replenishment systems. Concept was that they fed a very small amount of oil through the injection system and burnt it slowly so that all that was needed was the addition of oil to top off when needed. Saved service time, did away with oil disposal requirement, saved liability of oil drainage in workshops etc and consequent loose plugs and forgotten refills etc. larger sumps and remote reservoirs provided reserve capacity. Big benefit was that oil quality on average was better as it never degraded to the end of oil change interval when additives were depleted.
Hi everyone,
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Great news Charles. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
I can't believe they dropped the sump bung in a JLR main dealers! Are you quite sure you were not watching him do something else sir? JLR dealers all service cars to the manufacturers specs and a 4.4TDV8 is definitely a suck oil out engine as per JLR Topix...
It's booked in today at a main dealer. So I will update you later.
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
5w/30 AF-L WSS-M2C934-B . |
Quick update. No more leaks and oil level is fine. Looks like the inner V was full of oil from the oil seal breaking and has finally burnt off. |
