Home > Technical (L322) > Please help range rover L322 4.4 tdv8 2011 misfiring !
Bobby
United Kingdom 2011 Range Rover Autobiography TDV8 Mariana Black
I recently had the battery replaced on my Range rover, car drove fine for a few weeks.
On my way back home one evening my fuel gauge all of a sudden went to empty, even though I had a full tank of diesel. 20 mins later I had all a number of other warning light come up, battery, charging system not working etc. car also started to misfire
I got home lift the bonnet open and found out both of my battery terminals were lose.
I adjust the clamps so they were tighter round the battery terminals car started battery warning lights have gone but my fuel gauge is still showing empty and the car is still misfiring.
Can someone please help advise, anyone come across this issue before.
Car drove 100% before the battery change.
Post #495530 14th Nov 2018 8:02am
Baltic Blue
Bobby,
I would open the bonnet, stop the engine, then leave the car for at least ten minutes to completely shutdown.
Then do a battery reset by removing both battery cables and holding them together.
After this, refit the cables and try again.
Post #495532 14th Nov 2018 8:49am
^ what mike says ....
also, after the battery clamps have been re-fitted turn the steering wheel hard left and then hard right to reset the steering parameters..
Post #495533 14th Nov 2018 8:54am
Bobby
Thanks Mike, Will try this, just to double check , put both Positive and negative terminals together.
Much appreciated !
Bob
Post #495534 14th Nov 2018 9:15am
mjdronfield
Yeah mate. The 2 cables on the car, touch them together. Battery not involved.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #495541 14th Nov 2018 10:38am
Stan, that only works on pre 07 cars sir Thumbs Up Thumbs Up
Post #495542 14th Nov 2018 10:45am
Without removing the battery you won't get enough room to literally touch the battery leads together sir...
So, if you use a jump lead and remove the battery terminals, cover that terminals with a piece of something non conductive! Then attach the jump lead to the removed terminals (now with no chance of touching the battery as its insulated) for 3-5 seconds and bobs your aunties cat!!! Battery hard reset performed... Remove the insulated cover and Re-attatch the battery terminals... Thumbs Up
Remember its attach the live terminal first, then the earth... Try to attach the earth in ONE fluid motion Thumbs Up
Post #495544 14th Nov 2018 10:54am
Baltic Blue
Thanks Craig,
I didn’t know that it only applied to earlier models and have been doing it out of habit after each battery disconnection.
Post #495547 14th Nov 2018 11:04am
I think it was a BMW thing Mike, as soon as Ford took over, i guess the steering angle sensor was upgraded to keep its memory... Thumbs Up
Post #495548 14th Nov 2018 11:19am
thanks for the info craig... Thumbs Up
Post #495553 14th Nov 2018 12:14pm
cass
If the fuel gauge is still reading empty then the sender unit wiring is causing your problem
Mine did the same, because the car thinks its empty it shuts down for some obscure reason
I did a post about this when it happened to me but I can’t find it on my phone
Post #495555 14th Nov 2018 12:40pm
Bobby
I really appreciate your info guys you all been very helpful.
The last thing I want to do is give it the Land rover and they sting me with a heavy bill. They tend to do that.
I will do this when i get home home today.
Mine is a 2011 so wouldn't need to do the steering lock from left to right ?
Thanks
Post #495558 14th Nov 2018 1:39pm
Bobby
If the fuel gauge is still reading empty would this cause the engine to run lumpy ?
Is so what is the process in getting this fixed ?
Post #495559 14th Nov 2018 1:43pm
thats right bobby, craig has advised and he knows his stuff so no need to set the steering parameters....
Post #495560 14th Nov 2018 1:45pm
cass
The fuel sender is a known problem, there’s a TSB explaining the fix. Someone (I can’t remember who) did a good write up with pictures on here.
It’s not difficult just a bit fiddly
Post #495570 14th Nov 2018 3:23pm
