Home > Technical (L322) > Please help range rover L322 4.4 tdv8 2011 misfiring ! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Bobby,
14th Nov 2018 8:49am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
^ what mike says ....
14th Nov 2018 8:54am |
Bobby Member Since: 02 Oct 2015 Location: London Posts: 26 |
Thanks Mike, Will try this, just to double check , put both Positive and negative terminals together.
14th Nov 2018 9:15am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7804 |
Yeah mate. The 2 cables on the car, touch them together. Battery not involved.
14th Nov 2018 10:38am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Stan, that only works on pre 07 cars sir |
14th Nov 2018 10:45am |
Without removing the battery you won't get enough room to literally touch the battery leads together sir... So, if you use a jump lead and remove the battery terminals, cover that terminals with a piece of something non conductive! Then attach the jump lead to the removed terminals (now with no chance of touching the battery as its insulated) for 3-5 seconds and bobs your aunties cat!!! Battery hard reset performed... Remove the insulated cover and Re-attatch the battery terminals... Remember its attach the live terminal first, then the earth... Try to attach the earth in ONE fluid motion |
14th Nov 2018 10:54am |
Thanks Craig,
14th Nov 2018 11:04am |
I think it was a BMW thing Mike, as soon as Ford took over, i guess the steering angle sensor was upgraded to keep its memory... |
14th Nov 2018 11:19am |
thanks for the info craig... |
14th Nov 2018 12:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 739 |
If the fuel gauge is still reading empty then the sender unit wiring is causing your problem
14th Nov 2018 12:40pm |
I really appreciate your info guys you all been very helpful.
14th Nov 2018 1:39pm |
If the fuel gauge is still reading empty would this cause the engine to run lumpy ?
14th Nov 2018 1:43pm |
thats right bobby, craig has advised and he knows his stuff so no need to set the steering parameters.... |
14th Nov 2018 1:45pm |
The fuel sender is a known problem, there’s a TSB explaining the fix. Someone (I can’t remember who) did a good write up with pictures on here.
14th Nov 2018 3:23pm |
