Home > Maintenance & Mods (L322) > Turbo drain mod |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Glad it worked out well
28th Oct 2018 10:55am |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 490 |
definitely worth doing and not burning the oil. Cheers
28th Oct 2018 2:47pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I have to say I'm absolutely delighted, I had my son following behind today down in Bath and we'd driven around for about 50 miles yesterday, nowhere near 2000 rpm loads of stop / starts and this morning I asked him to video the back of it when I gave it kickdown going up a steep hill. It hung on to the gears and rocketed up the hill, not even a hint of any smoke. I really cant believe that it is an effective cure.
28th Oct 2018 7:11pm |
Lavazza Member Since: 03 Oct 2018 Location: Lake District Posts: 29 |
I bought a car that hasn't had the drain mod yet. It's under LR Warranty; no indication of any issue. Is a problem arising the only legitimate trigger for the TSB being enacted under warranty, or can I simply request that the mod is carried out? |
30th Oct 2018 8:08pm |
See if you have the problem first (not all do apparently). If I drove mine around town keeping below 2000 rpm (not difficult), the first time after you use 2500 to 3500 rev range it was like something out of a bond movie, thick blue smoke screen for 30 to 40 seconds which the faded away. Once done it would remain clear until the oil built up again. BMW i3 Electric Car
30th Oct 2018 8:29pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Been thinking about this.... I've read through the TSB instructions and the main, scary job is removing a block plug, drilling it and tapping it to fit a hose adaptor. The new twin drain has the additional hose which goes onto the hose adaptor.
12th Nov 2018 10:28pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
A 12mm hole needs to be drilled through to the inside before tapping a thread. A smaller hole already exists but presumably its not large enough.
12th Nov 2018 11:26pm |
I guess I'm wondering what the ID of the hose is.
12th Nov 2018 11:31pm |
Yes new plug.
12th Nov 2018 11:32pm |
The TSB states the use of a sealant around the outside edge of the plug post fitting.
12th Nov 2018 11:49pm |
When Green Oval did mine, the whole front subframe came off, it was 8 hrs or thereabouts up on a ramp. Afterwards a wheel alignment specialist reset all of the geometry. For me, whilst I'm not afraid of working on cars there was a bit too much hassle there, happy to pay the cash and let someone else skin their knuckles etc.
13th Nov 2018 5:11am |
Just a very quick update, 3 weeks since my turbo drain mod was done by Green Oval Garage, I have don't a huge mix of driving including 250+ miles just dawdling around. Despite my best efforts to make it smoke, nothing, clean as a whistle. I'm delighted to have fixed this somewhat embarrassing problem. Thoroughly recommend getting the mod done if your FFRR is affected, if you're within travelling distance of Green Oval Garage, I cant recommend them highly enough. BMW i3 Electric Car
16th Nov 2018 3:55pm |
Westminster263 Member Since: 03 Feb 2022 Location: 09390 Posts: 3 |
Hi there,
23rd Feb 2022 1:38pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
It doesn't matter how hard I try I can't get mine to produce smoke. Am I not trying hard enough? or is it safe to assume the mod just doesn't need doing? Geoff |
23rd Feb 2022 2:54pm |
