![]() | Home > Technical (L322) > Rear reversing light casing |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
A little silicone sealant will be your friend |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Yep.
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Cheers guys, much appreciated!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
For info, the lens cover should have a tab at the bottom that slots into a hole, and it should be held at the top with a philips screw (bolt) into a plastic fixing.
Joe, I think the OP had just the lens cap fall off, not the whole unit fall out |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I had this same problem a few weeks back and can confirm the silicone does work. While they’re off it gives you a chance to give them a good clean inside before you stick them on |
