Home > Technical (L322) > Rear reversing light casing
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi all,
Just wanted to check something with you before I order a new part, got a feeling I'm missing something.
As I've closed the tailgate earlier today, the right hand reversing light cover has fallen away, just leaving the exposed reflector/bulb behind. I've gone to reattach it, but there don't seem to be any parts that click or slot together, leading me to think that it's meant to be a complete unit, and I may need to replace it all. Am I missing something here, or does the whole light need to be replaced?
Thanks!
Post #493764 27th Oct 2018 3:40pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
A little silicone sealant will be your friend Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #493765 27th Oct 2018 3:47pm
Yep.
Mine dropped off in the car wash once. I stuck it back on with some mitre fix superglue and activator. As good as new and you can’t see the Adesive. Go buy some, dead useful for loads of stuff and save yourself a fair bit on a new reversing lamp. There is nothing that can't be fixed with a hammer😜😜
Post #493767 27th Oct 2018 4:12pm
gj88
Cheers guys, much appreciated!!
Post #493769 27th Oct 2018 4:51pm
For info, the lens cover should have a tab at the bottom that slots into a hole, and it should be held at the top with a philips screw (bolt) into a plastic fixing.
Probably the top locating ring in the lens has broken off, or the tab at the bottom. .
Post #493785 27th Oct 2018 6:15pm
Bushy30
Joe, I think the OP had just the lens cap fall off, not the whole unit fall out Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #493792 27th Oct 2018 7:01pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I had this same problem a few weeks back and can confirm the silicone does work. While they’re off it gives you a chance to give them a good clean inside before you stick them on
Post #493834 28th Oct 2018 9:43am
