Home > Technical (L322) > Rear reversing light casing |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
A little silicone sealant will be your friend Current: 2011 FFRR Vogue SE 4.4 TDV8
27th Oct 2018 2:47pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8500 |
Yep.
27th Oct 2018 3:12pm |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Cheers guys, much appreciated!! |
27th Oct 2018 3:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
For info, the lens cover should have a tab at the bottom that slots into a hole, and it should be held at the top with a philips screw (bolt) into a plastic fixing.
27th Oct 2018 5:15pm |
Joe, I think the OP had just the lens cap fall off, not the whole unit fall out Current: 2011 FFRR Vogue SE 4.4 TDV8
27th Oct 2018 6:01pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I had this same problem a few weeks back and can confirm the silicone does work. While they’re off it gives you a chance to give them a good clean inside before you stick them on |
28th Oct 2018 8:43am |
