Home > Maintenance & Mods (L322) > Westfalia detachable tow hitch |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Seems to be only one.. Guess I'll just need a bigger hammer.
23rd Oct 2018 8:17am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
if not removed regularly they do get stuck...
23rd Oct 2018 10:39am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Agreed
23rd Oct 2018 12:32pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
I have had much better results using Plugas, WD40 is very good for lubricating etc but for freeing off seized parts it cant be beaten.
23rd Oct 2018 12:34pm |
I've only owned the car for a week, so re-lubricating the tow bar was on the to-do list. Obviously a few years to late.
23rd Oct 2018 4:49pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Is there a proper plastic plug that can be fitted in the square receiver? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Oct 2018 6:05pm |
There is a square one with the LR logo.
23rd Oct 2018 6:16pm |
23rd Oct 2018 8:27pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Ours was similarly stuck. Try as I might, I couldn't get it out over a period of many weeks lubricating it and hammering it.
23rd Oct 2018 8:37pm |
Might try a trolley jack under it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
23rd Oct 2018 8:44pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 |
The slot in the removable part isn't for a bolt, but lines up with a pin permanently welded into the tube which locates the front end, stops it being pushed in too far and shares the over-run load with the bolt.
25th Oct 2018 8:10am |
What size socket is needed for the bolt? I ran out of socket sizes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Oct 2018 2:20pm |
I believe it's a 24mm.
28th Oct 2018 2:55pm |
Air gun here we come Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Oct 2018 3:22pm |
