Home > General > What Did You Do In Your Full Fat Today
Page 286 of 379 <123 ... 285286287 ... 377378379>
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Engine oil & filter changed. Transmission flushed by pumping out dark grey fluid out of the cooler line. Fresh oil in the old fashioned way. Very time consuming and awkward. Diffs and transfer box oils changed. Quick test drive with a smug grin and all is wonderful.
Discs and pads to do in the week. Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #491368 7th Oct 2018 9:08pm
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Took it in to have the head gasket changed as it had blown.
Wallet on standby to be emptied! Big Cry
Post #491661 10th Oct 2018 5:32am
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Took the space saver spare wheel out to fit a full sized alloy I bought from Ebay. Got the space saver out fine and then used my newly purchased spare wheel 'winch' strap to lift the bloody heavy spare wheel in. Then realised the boot floor wouldn't sit flat so had to take the spare out again and remove the grey polystyrene ring and then lift the spare back in again Rolling Eyes How anybody could get the spare wheel out without one of these lifting straps is beyond me although, I suppose mine didn't have one as it was originally specced with a space saver Evil or Very Mad
Off for a lie down now Laughing Cheers Ian
Kielder 4x4 Safari
Post #492263 14th Oct 2018 2:57pm
Hairy Dan
Took it for a service Sad Glad to report no extra work needed although on the MOT earlier this year the tester reported that the pads were just about worn out and the discs were badly worn, so I was expecting 'the phone call'. when I picked the car up just now they said the pads had about 50% life left in them and the discs are fine Confused I wonder if the last main dealer was touting for some work? Evil or Very Mad Cheers Ian
Kielder 4x4 Safari
Post #492563 16th Oct 2018 4:03pm
Grofus
New rear discs and pads. Had handbrake shoes, pins and springs to fit too but when inspected they were virtually new. It had recent back plates too. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #492605 16th Oct 2018 8:41pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Done it so many times .... you need to be in the boot - not stood outside Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #492606 16th Oct 2018 8:45pm
DMRR
I know what you mean - when you can do 45,000 miles on a set and then be told 5,000 miles after fitting a new set that 'they're worn and need replacing.....' - yeah that. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #492607 16th Oct 2018 8:47pm
nearlee
Wales
Made a mess of it Big Cry
 Remember:- amateurs built the ark
Proffesionals built the titanic
Post #493067 20th Oct 2018 9:25pm
Baltic Blue
Have you any idea how long it took me to clean those wheels, Rolling with laughter Thumbs Up Thumbs Up
Post #493084 21st Oct 2018 7:43am
nearlee
Wales
Don't worry Mike there absolutely spotless under the mud Mr. Green Remember:- amateurs built the ark
Post #493097 21st Oct 2018 11:28am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Headlight polishing day.
Before,
After
Post #493126 21st Oct 2018 3:54pm
Dizzy Dee
Thats good that, What product did you use please?
Post #493151 21st Oct 2018 6:47pm
S.Hafsmo
I used Meguiars Heavy Duty Headlight restoration kit.
I've used a similar 3M kit in the past, but I think the Mequiars kit is more suitable to these headlamps, as they do not have a flat face.
The "Before" pic really doesn't do justice, as they looked really rather aweful. Satisfied with the result, though.
Are these lenses replaceable?
Post #493153 21st Oct 2018 6:55pm
Dizzy Dee
Thank you
Post #493159 21st Oct 2018 7:51pm
mark35gun
United Kingdom 2011 Range Rover Autobiography Black TDV8 Santorini Black
changed the oil and filter finally sussed out the bovee wma1000 thanks to Cass Very Happy 2011 4.4 tdv8 autobiography black
2006 td6 vogue buckingham blue
2000 p38 Holland&Holland gone, best car i ever had
1998 p38 vogue oslo blue gone
1998 50th edition v8 defender gone
1997 200 tdi defender red gone
1995 4.6 defender 90 green gone
Post #493293 22nd Oct 2018 7:26pm
